Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 05-08-2017, 02:42 AM   #41
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Rich, I have the same problem with gray water! Cannot get my wife to use less. We do some boondocking next month so I get to test my system in use.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-08-2017, 06:36 AM   #42
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Franks solar upgrade on a 2016 FC 27'
Cool Larry. I have read a thread or two where they combined the grey and black tanks, now I see why.
Sounds Like too much work. At one point I was holding grey in the sink then using a bucket to put it in the black! I guess you get better the more you practice!
Troutboy
Troutboy is offline   Reply With Quote
Old 05-11-2017, 04:07 PM   #43
1978 31' Sovereign
2016 25' International
Bryan , Texas
This is a solar newbie question. Any chance you can fire up an Air Conditioner with this system? Maybe with the addition of an EasyStart?
Dannyfishes is offline   Reply With Quote
Old 05-11-2017, 04:40 PM   #44
Troutboy's Avatar
Parker , Colorado
Check out this post:
http://www.airforums.com/forums/f449...ll-166625.html
I explain how I ran AC and Rawn77 the OP discussed how he runs AC at night. He has a massive battery bank. That is the key. But with a hybrid inverter and large batteries, you can do it for short times.
Troutboy
Old 05-11-2017, 07:40 PM   #45
1978 31' Sovereign
Bryan , Texas
Thanks!
Old 06-13-2017, 07:22 PM   #46
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
My air conditioner starts fine without an easy start, but that's more a function of the 330 AH lithium battery and victron 3000 multiplus inverter than the solar upgrades. Will have to see how long I can run it with and without the help of the sun and solar system. --Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 06-24-2018, 05:42 AM   #47
fran&frank's Avatar
I decided to add a fifth panel to my system while panels are still reasonably priced. Decided to put it in the front where it was not likely to be shaded by an AC unit and also so it had a slightly different pitch so it might be better oriented to the sun when some of the others are not. Since it was at the very front of the trailer I used a continuous piece of aluminum angle for the front mount to keep the wind from getting under it. I just notched the one side of the angle then bent it to match the curvature of the roof, and attached with vhb tape and sikaflex. I also added a Victron Venus GX (that's a different post) so now I need to get out and start monitoring its performance --Frank
Name:	roof panels.jpg
Frank & Fran
Equalizer Hitch
Old 08-21-2018, 09:32 AM   #48
marter's Avatar
2008 19' International
Lincoln , Nebraska
Fran&Frank,
I love your panel mounts and want to do something similar for a couple Renogy panels on my 19' International. In view of the potential of a voided warranty, I'm considering using the VHB tape and Sikaflex method with Renogy"s mounting brackets [URL="https://www.renogy.com/renogy-solar-panel-mounting-z-bracket-set-of-4"] but wonder if they would provide enough surface area for adhesion.
Any opinion? BTW great job on your solar and thanks for posting.
Happy trails,
Mike
marter is offline   Reply With Quote
Old 10-28-2018, 07:09 AM   #49
fran&frank's Avatar
Sorry I have no experience with the Renogy mounts. I only became aware of the possible warranty issue related to screwing through the side of the panel after mounting my panels my way. Had I thought of that before hand I might have mounted them differently using homemade brackets that utilized existing holes on the panels.
Frank & Fran
Equalizer Hitch
Old 03-11-2020, 05:31 PM   #50
fran&frank's Avatar
It must be a disease. I decided to add a sixth solar panel to the roof of my trailer. So in looking at where to place it I came up with this location at the back of the trailer because there is less chance of it being shaded than if placed next to one of the AC units. I just have it temporarily sitting there at the moment. I don't think I have seen any posts of anyone putting a panel in this location. Does anyone see a downside to this location? It does require folding the radio antenna horizontal and will cover about half of it. --Frank
Frank & Fran
Equalizer Hitch
Old 03-14-2020, 08:00 PM   #51
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Frank
It looks good to me. Solar panels are relatively cheap. I say as long as you have room for more solar, go ahead and install it. You need to cover yourself when you are camping in the shade or there is cloudy weather.
Dan
Old 06-07-2021, 10:04 AM   #52
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Frank, Nice install and an interesting thread. I'm getting ready to do large install myself. So, today I'm just kind of lurking, looking for shoulders to stand on. Heh, heh.
I couldn't help but notice that the dialog ended abruptly about the time Covid 19 took off. I hope you and yours are doing okay. If you have more posted elsewhere please let me know.
Best wishes.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 09-21-2023, 04:59 AM   #53
Bauxter's Avatar
Sunset Beach , North Carolina
looking for updates on 6 year old thread
Several folks on this thread built their own solar panel mounting brackets using off the shelf aluminum angle.
Does anyone have any regrets using that product. I ask because AM Solar uses stainless steel for their pivoting mounts, which seems stronger, and looks great, but is a great deal more money than stock aluminum angle.
I was curious if anyone had metal fatigue issues with the aluminum angle brackets.
Bauxter is offline   Reply With Quote
2016 Bambi Sport 16 tire upgrade to 15" Viggen 2005 and newer - Bambi all models 24 02-27-2019 07:26 AM
235 AH Battery Upgrade on 2016 19’ Flying Cloud Snowy Batteries, Univolts, Converters & Inverters 12 04-07-2017 06:49 PM
2016 Sport Bambi 22FB Tire Upgrade ? jcole 2005 and newer - Bambi all models 7 02-23-2016 06:11 AM
Converter,battery and solar upgrade SilverSinbad Batteries, Univolts, Converters & Inverters 2 01-19-2015 10:57 AM
Solar upgrade beerrun'r Generators & Solar Power 1 09-21-2013 03:00 PM
