Old 05-04-2020, 01:30 PM   #1
2013 23' FB Flying Cloud
Lakewood , Washington
Flex Solar Panel Removal
Plan to replace the existing pair of 7 yr old flex panels with rigid units this month. Existing panels are installed with 12 rivets each with sealant above/below panel. I'm guessing I'll need to drill out the rivets, and attack the remaining sealant with plastic blades. Fill the holes with one of the following-plastic plugs, plastic push rivets, or aluminum rivets, with 221 lubing and covering the chosen hole filler. Any of you fine folks gone though this and have a preferred plug method? Thanks, and hope you all are staying sane.
vlaming is offline   Reply With Quote
Replacing solar roof flex panel Garfish Generators & Solar Power 36 11-15-2019 12:25 PM
Can a portable solar panel be added to a factory solar system? larry9000 Generators & Solar Power 7 10-14-2017 04:35 PM
100W Flex Solar panel, Controller & Display JayP Airstream Classifieds 0 07-04-2016 04:45 PM
New Flex Solar DIY Project RaymondFitz Generators & Solar Power 36 07-28-2015 09:50 PM
