Old 10-01-2019, 11:57 AM   #1
Fixed and portable solar simultaneously
Hey all. New 2020 Bambi 22 owner here. Got dealer-installed 2 ESP/Watt Mobile solar panels on the roof and MPPT controller. Can I add portable panels when using the Zamp Solar connector at the front of the Airstream? The portable kit Im considering is the Zamp Solar USP1002 with built in controller. Any insight appreciated. Thanks.
steilkurve is offline   Reply With Quote
Old 10-01-2019, 02:30 PM   #2
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Originally Posted by steilkurve View Post
Hey all. New 2020 Bambi 22’ owner here. Got dealer-installed 2 ESP/Watt Mobile solar panels on the roof and MPPT controller. Can I add portable panels when using the Zamp Solar connector at the front of the Airstream? The portable kit I’m considering is the Zamp Solar USP1002 with built-in controller. Any insight appreciated. Thanks.
The connector in the front goes directly to the battery. You can run a second controller (I do). It will feed the batteries fine when controllers are on bulk mode, but you may get one controller shutting down or going into a trickle as the other panels finish up charging. It will not hurt your batteries.
It does work though and is better than not having the portable panel.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 10-01-2019, 08:54 PM   #3
1971 27' Overlander
Kansas City , Kansas
Has been discussed pretty extensively here.
http://www.airforums.com/forums/f448...ml#post2195208
Shermy1987 is offline   Reply With Quote
Fixed vs Portable solar panels Rig Rat Sprinter and B-van Forum 67 02-17-2019 12:39 PM
Can a portable solar panel be added to a factory solar system? larry9000 Generators & Solar Power 7 10-14-2017 04:35 PM
Supplement Factory Solar with Portable Solar dkottum Generators & Solar Power 10 06-16-2016 03:28 PM
