08-05-2019, 08:46 PM
2016 26' Flying Cloud
Southlake
Finally installed Easy Start
I had to wait until one of the hottest days of the year to get on the roof. Install was pretty straightforward. Hardest thing was not getting cramps in my 74 year old body! Startup amps is now 15-16 after the learning process. I should be able to leave one of my Honda 2000 generators at home now. We don’t usually camp without full hookups, but we plan on several days at the north rim of the Grand Canyon and several in the Davis Mountains on the trip home. I also replaced the 4 yr old Interstate 12v batteries with Trojan 6v’s.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
08-06-2019, 04:37 AM
2018 30' Classic
Cumberland
, Maryland
We also had Easy Starts installed at Doswell plus purchased Hutch Mountain propane regulator and a Honda EU2200i with propane conversion. Hooked up to propane and generator goes into overload after about five minutes of running one AC. Will investigate further today, need to make up something so I can measure the current. Slightly disappointed at this point.
08-06-2019, 04:41 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
It will work out. I can run my 15K unit on a Honda 2000eu.
Did you do all the “Learn Starts”?
08-06-2019, 04:47 AM
2014 25' Flying Cloud
Cuddebackville
, New York
And did you make sure there were no other loads on the generator- refrigerator, converter, water heater on electric?
If it overloaded after some time, probably something else kicked on. The converter did it to me.
2019 Ford Expedition Platinum
08-06-2019, 05:22 AM
2009 25' FB International
2018 27' Globetrotter
Tavares
Just tagging along to see what resolved this issue!
08-06-2019, 09:11 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
2018 FC25RT
I will have to check if something else kicked in, because my Yamaha 2000 overloaded when I only used one.
Am I wrong to assume that one gen should operate a single AC unit assuming nothing else was running (Microwave, TV, etc.)?
08-06-2019, 09:15 AM
2020 30' Classic
2015 25' Flying Cloud
Blue Ridge
, Georgia
Found out that running the AC with the Honda 2000 after Easy Start worked fine but could not run anything else without tripping the breaker. Mainly the refrigerator. Did not try running TV or any other elect devices while the AC was on generator.
08-06-2019, 09:19 AM
2016 25' Flying Cloud
Selbyville
, Delaware
You have to run your refrigerator and HW heater on propane while running A/C on a single Honda EU 20001. And obviously no microwave!
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel
WBCCI #9026 Delmarva Unit
08-06-2019, 09:21 AM
Selbyville
, Delaware
And does anyone know for sure that if you install an Easy Start before your AC warranty runs out that it will void the warranty?
Jamie
08-06-2019, 11:13 AM
Camping Dutchman
2018 33' Classic
Manchester center
, Vermont
How to switch off converter on a 2018 classic?
Anybody knows how to switch off the converter on a 2018 classic so no auxiliary power is drawn while running Ac on Honda 2000 with easy start?
Is it simply a breaker? Have not been at my trailer and tested my easy start set up with generator.
My understanding is that you turn on converter when turning off the Ac and charge up the batteries.
I have solar too.
08-06-2019, 12:49 PM
1998 31' Excella 1000
Clear Lake
Originally Posted by truffies
Question: Site says Specs; Working voltage 80-260VAC/Test Voltage: Same.
So how dies this work on 12 volt DC?
08-06-2019, 04:11 PM
2018 30' Classic
Cumberland
, Maryland
Well remember I am running off Propane which reduces my power. Converter is off while running one AC with my EU2200i off propane. It (the gen) is basically running at it's limits and the Easy Start views the generator as getting ready to fail and it shuts down. At least that's one explanation. We will do some more testing but will have to wait under we get our Classic out of the shop. Also found out rear AC will run with ECO Throttle in the off position.
FYI, AC running full bore at around 15 amps.
GMFL: Yes we did all the starts and then some.
Wayne & Sam: Converter is off.
jamieb1086: Per Dometic Easy Start will not void warranty
08-06-2019, 04:23 PM
Bluffton
, South Carolina
I had a older Honda 2000 when I installed easy start on our 15k ac earlier this year. With converter breaker switched off and refrigerator on propane and everything else off I couldn’t get it to run AC on gas. Did tuneup on gen still no go. Next bought a new 2200 and had no problem on gas. Don’t know if it would work on propane. So I’ve put a hold on ordering the Hutch Mountain propane regulator. My EMS says I’m drawing 14 amps from 15k ac.
08-06-2019, 05:11 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Power
On propane there is less power output on any engine not designed with a timing map curve to handle propane. Also there is no lubrication on the exhaust valve with propane
A dual fuel dedicated generator is usually more effective than a conversion
08-06-2019, 06:52 PM
2018 16' Sport
Salt Lake City
, Utah
The guys at Airstream Factory Service Center told me that installing the easy start would void the warranty for my air conditioner. I had about a year left on my warranty but decided to go for it anyway. The easy start makes it possible to run the air conditioner with my Genconnex propane powered Honda 2200 generator. I think it was way worth the warranty trade off.
08-06-2019, 07:24 PM
2007 22' International CCD
Corona
MicroAir covers the Air conditioner against their EasyStart causing problems once their unit is installed. See their website for details
08-06-2019, 11:52 PM
2007 27' Safari FB SE
Rancho Murieta
Can I run my AC with easy start on my home 110v?
08-07-2019, 02:36 AM
2018 30' Classic
Cumberland
, Maryland
For a fee they have a blanket policy
08-07-2019, 03:12 AM
Stay Calm and Stream On
2017 25' Flying Cloud
Palm Springs
I have found for me the Honda 2200i will not run 15k AC at about 7000 feet in Santa Fe New Mexico with Refrigerator on propane and nothing else on. Same situation, the AC runs for about five minutes and then shuts compressor off. I also have Zamp 180 portable and batteries at 90% +. I did not switch off converter.
Stay Calm and Stream On!
