08-23-2020, 08:13 AM
2018 27' Flying Cloud
Austin
Factory Solar Installation?
We're dipping our toes into the solar market. So I've started doing my research... along with this I've considered doing the installation myself, but I've also thought why not allow the factory do it.
Anybody ever have the factory do their solar installation? If so, I'm curious how it worked out for you. Basically we're looking to run pretty much everything minus the AC which may be asking for too much from the factory system. (I'm not sure even what the factory will or won't install).
08-23-2020, 08:38 AM
2017 30' International
Broomfield
The factory / Airstream are not specialists in solar energy production, storage and management. There are specialized installers out in the market for a reason.
AM Solar
Lew Farber (Solar Tech)
Ronnie Dennis (Airstream nuts and bolts)
Precision RV
Etc
You’ll note that I have not listed any airstream dealerships above.
Working with a professional who specializes in these systems is worth the money if you are going to choose not to design / install yourself.
If you do decide to tackle this yourself, there are plenty of forum members who can guide you on design, materials and installation techniques.
Finally, just FYI, in the 2020 tax year you also get a federal tax credit back for 26% of the cost for install labor and parts/equipment for a solar production and storage solution on your airstream.
08-23-2020, 12:47 PM
Furthur
2021 25' Flying Cloud
2015 22' FB Sport
Golden
Wulfraat, I noticed your recommendation for Precision RV. I have a new FC 25 FBT on order and have been looking around for a reputable local (Denver area) company for solar installation. Have you or others had experience with Precision or other companies in Colorado?
08-23-2020, 02:35 PM
Broomfield
Don’t have experience with Precision, have only heard good things about them.
No specialists in Denver area that I am aware of. For my install I made the 2 day drive north to pay a visit to Lew Farber in hood river, OR...
08-23-2020, 02:59 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
This is not a plug for myself, but the factory or RV dealer is no the place to get a functional solar package installed. They just don’t have the time to commit to do what it takes to do a quality job.
08-23-2020, 03:45 PM
Evergreen
I just bought an International 23FB with the factory rooftop 180W solar package and upgraded AGM batteries. I'm interested to see how it performs. I will be adding a ZAMP portable solar panel to help, especially for those times when the trailer is parked in shady areas. I'm leaning towards the 230W portable panel at this point. Most of my boondocking trips will be 3 or 4 day weekends, so I think I'll be fine. We typically camp in the mountains, so not running the A/C doesn't worry me too much.
The solar power subject seems to be a deep rabbit hole. It's interesting stuff.
09-05-2020, 05:52 PM
2021 25' Globetrotter
Somewhere
We decided to upgrade from our 23FB to a 25FB - this one has solar from the factory.
Had the dealer take a picture of the compartment and it appears to be the typical rats nest is there.
Interestingly I also note a lack of breaker and shut off switch from the panels.
Looks like a get to do a bit of a project after all.
09-08-2020, 07:09 PM
2020 20' Bambi
Clayton
, North Carolina
Agreed, based on what I saw on my roof. I have the AS Zamp 90W factory installed and I ordered another Zamp 90W and installed myself. What I saw regarding the AS favtory install. The hold down brackets on the roof centerline side have three holes per bracket for the self tapping aluminum screws to hold the bravket to the frame. They only used two screws in each bracket. On the curb/outer side the brackets are held in place on the frame with a bolt, lock washer and inset square nut with spring backing. They did not install the lock washers. And now with the panel 3M taped and Silaflexed to the roof it is almost impossible to get the bolts out and lock washers installed without removing the panels. So disappointed in the rush work on the February 2020 build.
09-08-2020, 07:18 PM
2020 20' Bambi
Clayton
, North Carolina
Just an FYI. I initially purchased the Zamp 230W portable and found it a bit unwieldy at almost 50 lbs. It is not the weight in and of itself that is the issue for me (I can lug around a 47lb portable inverter gen), it is the fact that the weight is distributed over a large surface area. And the handle is a bit edged instead of rounded and it digs into your hand. I sent it back and got the 180W which is only 35lb over a smaller surface area. Much easier to lug around. And based on how well I see my 180W of rooftop solar charging through an upgraded Victron 100/30 MPPT solar charger, I think the 180 portable will do just about as good a job through its own Zamp charge controller.
10-03-2020, 01:23 PM
2017 Interstate Grand Tour Ext
Ventura
Lithium upgrade
Any recommendations for an installer in California, preferably in So. Ca.
10-31-2020, 09:38 AM
2021 23' International
P
I'm looking for an experienced installer in So Cal also. Please post your results.
12-07-2020, 08:06 PM
2021 27' Flying Cloud
Virginia Beach
, Virginia
If you have the AS factory installed solar package and decide to add a portable panel setup, can the charge controller handle an additional 230 amps? Anyone know for sure or have experience? Just picked up our 2021 FC 27FB look at future needs.
12-11-2020, 03:51 PM
2015 20' Flying Cloud
Kingsport
, Tennessee
Question: 2016 and newer AS's have the Zamp port up on the roof, into which the solar panels can be connected. Mine is a 2015, which is prewired for solar, but I don't think it has the same box. Reading the manual, it says the wires run to "under the center roof sheet, just behind the front roof vent". What would such look like up there right now? (I'm still in the process of buying it, haven't brought it home yet, so I can't run out and take a look.)
-Leslie
WBCCI #1051
12-11-2020, 03:58 PM
2022 25' Flying Cloud
NCR
, Ontario
IMHO, AS factory is not yet the best means to add solar.
maybe in a few years from now, but not today
You are better off on sourcing the correct panels, wiring, controller breakers and cut off switches yourself.
check the forum as i did a few years ago.
we went with BB lion batteries and the suite of Victron energy products.
AS factory is not there yet. as well , you can make a much cleaner install than the rats nest you do
cheers
12-11-2020, 06:19 PM
2019 27' International
Western NC
, North Carolina
You would run the portable panels to the plug by the battery with their own charge controller. I.e. in parallel to the roof mounted panels.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
