02-26-2020, 11:17 AM
#521
KW
, Ontario
Hi
We have stayed at a number of campsites where the panels dropped to near nothing for most of the day. Pretty much no sun on any panel outside a 1 or 2 hour window.
Yup that can happen. Just need to find better sites next time, or adjust your expectations. I've been on a few where it's been dark like in December and pouring rain, barely a charge. Just enough to keep the lights from draining the battery. But even after a few days of this the batteries didn't drop much further. You just need to control what you're using. Then when the weather is fine it's back up to 100% and you can go nuts using whatever. That's why I have multiple panels in parallel so that I can take advantage of the little bit power they are putting out. Anyone can charge their batteries in full sunlight.
02-27-2020, 03:42 PM
#522
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Well, the fridge pulls 1A in our trailer. The control system pulls another 1A. That gets us to right at 50A doing pretty much nothing all day long. The only way to go below that would be to shut down the fridge. I'm not into warm beer
Indeed we *do* turn on lights for a bit at night. We sometimes run the water / flush the toilet. I suppose we could use candles and dig a pit at the end of the campsite .. Probably higher up the list than warm beer
02-28-2020, 05:48 AM
#523
KW
, Ontario
Hi
Your fridge draws a lot of power. Mine did too and then I realized that the light inside was staying on all the time. Removed the bulb and presto it no longer drew 1 A. Almost nothing now. And my beer is ICE cold. In fact I keep 2 frozen steins in the freezer at all times just to make sure my beer is cold
02-28-2020, 05:58 AM
#524
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
POI...our fridge has a setting that keeps the light on ...ck the "low ambient switch". Keeps the temps up in cold weather so your Kom-quats don't freeze
Took me three years, but I finally learned that....when I read the manual.
BTW...Do NOT put an LED in the Fridge....Why I read the manual. 🥴
02-28-2020, 07:54 AM
#525
Oswego
BTW...Do NOT put an LED in the Fridge....Why I read the manual. [emoji3061]
[emoji631]
I put an led in. I have yet to find low enough temps that the temperature level selector hasn't taken care of....or shut the fridge off. I do keep the bulb in my supplies box if I ever do.
-Rich-
04-21-2020, 02:45 PM
#526
2015 Interstate Ext. Coach
Katy
2015 solar system operation
Hi,
I’m new to both the AI and solar panels / controller operation. I bought a 2015 3500 ext with 10 day contingency that all systems work as designed. I have not been able to validate the system and previous owner says he never used or understood the system. I have read the sunexplorer manual (pretty poor manual). Can someone walk me through operation as I have not been able to get any current (amps) to show up on the controller
04-28-2020, 02:54 PM
#527
2016 30' International
redondo beach
Originally Posted by pjeoss
Hi,
The only way I know to test your factory solar system is to put the Airstream in the sun and look at the controller and see if it draws any current. There is a display setting on the controller that indicates current in amps (A). And when in direct sunlight you should get some value like 3.2A or something like that.
Good luck with your purchase, whatever you are buying.
Not to sure what you mean by "AI"
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
04-29-2020, 05:52 AM
#528
KW
, Ontario
AI=Airstream Interstate
Sunexplorer = Garbage
Check your batteries and make sure they are still ok. Get a volt meter to confirm and then check the solar charge into the controller in full sun. Your current solar charger leaves something to be desired. Get a proper one, either MPPT or PWM (both Victron and Morningstar make quality ones). With the AI there are a number of ways that they can be wired. I'm not sure how the factory did it, but I'm sure that the folks with them can help you out better. A lot of the charging of the batteries on an AI will happen when the vehicle runs. It will need some proper electronics like DC-DC converters and a proper meter for the battery usage.
06-23-2020, 05:03 PM
#529
2020 30' Classic
Cary
, North Carolina
How to add Bluetooth to Victron Energy System
I have a 2020 with 270W factory installed solar using a Victron Bluesolar MPPT 150 | 35 Charger Controller. It is wired to a Victron MPPT Control Display. They are connected with a cable using the VE direct port on each device.
They make an optional Bluetooth dongle, but it has to connect to the VE Direct port. Is there another way to add bluetooth to the system without sacrificing the existing MPPT display?
07-12-2020, 07:05 AM
#530
2020 25' Flying Cloud
Alexandria
Originally Posted by SilverGate
So now it’s your turn…
If you have an Airstream with the factory-installed Solar Charging System, please share your experience, notes, information, and ideas here.
Others who are seriously interested in this system or have similar components of this system are also encouraged to share information.
Also, if you have in-depth knowledge about any of the system components, please share the information here.
SilverGate
I have a 2020 25FB Twin with factory solar w/2ea 100 w panels. The batteries are the Lifeline. Presently the unit is parked and in the sun in Minnesota. Day temps upper 80's night upper 60's. Inside temps of the trailer could hit 95F at the peak sun day. Each morning the display panel shows it's in a charging mode (came on as it detected less than 12.6v - input amp charge is about 3.2A). Nothing was ever 'on' in the trailer, use switch is off, always in "store" position. (CO detector comes on only when use switch is on - hooked up that way). The charging will take about 2 hours and the batteries come back up to 100% 12.8v. ( I measured this with a meter and have placed another digital charger on the batteries to verify the 100% charge). After about 2 hours again with no use the panel displays 90% then through out the day goes down to 85%. Nothing is running/on ever. I've confirmed this with a volt meter at the fuses showing no amp draw.
I cannot figure out why I'm loosing amps throughout the day? I cannot believe the temperature is that much of a factor as the mass of the two batteries would remain fairly even temperature wise. ?????Thanks for any inputs/ideas Benjamin
07-12-2020, 07:18 AM
#531
2012 25' FB International
Trent Woods
, North Carolina
I do not think you are. You are just measuring voltage. As long as the charge controller allows the panels to charge the batteries, the voltage will read higher since the panels are at 19 volts or more. Once the charge controller says "full" and shuts off, the voltage will drift down. A lead acid battery, at rest after a hour or so, fully charged is only about 12.6 volts. You need a a good battery monitor with a shunt to really know what is going on, at any given time.
Larry
07-13-2020, 01:17 AM
#532
2012 25' International
Prosser
Airstream installed our system after market. We have 240 watts on our roof. Our "charging" meter is the Zamp Solar digital readout. About a year ago, we replaced our batteries (AGM, Interstate 12V) and upgraded our charger to a smart charger (so it does not overcharge them). On a typical day of boon docking, we start out at 12.4 volts, which I am told is "healthy." The battery indicator is green. As the sun starts to shine on the panels, the voltage will jump to 14.4 volts and stay there for some time. Then we drop back to about 12.8 because we are now on trickle charge. Even with full sun our amp meter reads zero until we start using systems, and then energy starts going back into the battery to maintain that charge.
As long as your batteries are good/holding charge, I would not be concerned with any reading above 12 volts after running systems in the evening (refrigerator fan, range fan, water pump, and the biggie: furnace fan). As boondockers, we tend to find ways to save energy so we can be off grid. Extra down blanket to keep from running the furnace, removing the fuse from our refrigerator fan, and keeping that panel propped open to dissipate heat from the coils, etc. Our record for off grid is 8 days, after which, it is time to get more water and dump, but power is not an issue.
07-13-2020, 06:38 AM
#533
KW
, Ontario
The problem is the factory installed charger. Get rid of it. It is junk. It's killing your batteries. If all it charges to is 12.8V it is not doing you any favours. The lifelines need a much higher voltage to charge properly. See the lifeline manual. Then buy a proper solar charger like a MorningStar or a Victron. Set it for flooded batteries so that you will also get the equalization charge. Make sure the unit you buy has either a built in temperature sensor or the ability to add an external one (then wire it up). I'm using a cheap Prostar 30 for my 4 lifelines. Never an issue. Also get yourself a battery monitor so you can actually confirm the charge and the draw. Without it you will always be guessing. I use a Trimetric, but most AS'ers seem to gravitate towards the Victron prison.
01-15-2021, 11:59 AM
#534
2018 30' Flying Cloud
sebastian
Probably old question.
Got my new to me 2018 FC 30fb with factory installed solar.
two Zamp 90 watt panels laying flat on the roof top.
atkinson solar controller.
sunexplorer 2 display.
2 lifeline 90ah batteries.
I need more daily power replacement. I have been studying the system for 8 weeks and the max output I get from my panels is 17-20 watts and 1.6 - 2.6 amps. Ive washed the panels off and glanced at the wiring.
1) should I not get more watts output from my panels ? (depending on cloud conditions)
2) what should I expect from my 90 watt panels ? (in direct sun in central florida)
3) what can I look at in the system to see if something is not working properly?
IM sure this has been covered before maybe. I did a forum search and read about 8 pages of this particular thread but did find my specific question.
Thank you.
01-15-2021, 12:49 PM
#535
2019 27' Globetrotter
Litchfield Park
Thank you.
What you get depends on the angle of your trailer to the sun and how the panels are oriented to the sun. Remember also this time of year the sun is lower on the horizon. However, I would expect more wattage from two 90W panels in Florida than you are getting. Since you have factory solar, I would check on the roof at the junction box where the two panels plug in and make sure both are plugged in. There also may be some sort of connector on the back of the panels themselves. Check to make sure those connections are good too.
The other thing is, if your battery is charged or almost charged, the controller is not going to pass as much current. If the battery is charged you should see pretty much nothing in terms of output.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
01-15-2021, 12:51 PM
#536
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Sorry to be a little cynical, but that sounds like a typical factory install to me. If you want better results you'll likely need a do-over for both solar and batteries. However, whether that's worth doing depends on your camping goals with this trailer. For example, will you be camping without electrical hookups, or mostly in RV parks where they have power for you?
01-16-2021, 06:54 AM
#537
sebastian
Hey can I get up on the roof with a volt meter and measure the output from one panel from the plug ? would that be the way to test directly because whats coming off the controller is what is on the display. right?
01-16-2021, 06:59 AM
#538
sebastian
Oh BY THE WAY. I see your in Florida. Im in Sebastian Florida. I just upgraded to 2 BB batteries last weekend installing a new lithium controller and lithium converter. ( within my scope)
I want to get to 3-4 batteries - enough to run one ac for florida heat. Plus add some more panels to the roof. Im pretty sure I will need to upgrade my wiring and get my batteries out of the AS batt. box and in under the front bed. (probably not within my scope)
Do you know anyone close to me capable of that work?
01-16-2021, 09:40 AM
#539
Chelsea
, Maine
I hate to be the one to burst your bubble, but...
You are not going to run an AC for any reasonable length of time using only the solar panels that will fit on your roof. With enough batteries and a big inverter you can start the AC and run it until the batteries are depleted, but the solar isn’t going to keep up with demand.
You would need upwards of 1800 watts of solar panels given efficiency losses. That kind of system would require about 3 times your roof space, not to mention the massive wiring and robust charge controller.
Think.... Honda EU2200
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
01-16-2021, 09:56 AM
#540
Green Cove Springs
We used to have a 2017 International Signature 27FB, and had AM Solar in Oregon upgrade that unit with 650 watts of Solar, a pair of 200Ah Victron lithium batteries, a Victron solar controller, a 3kW Victron hybrid charger/inverter, and big fat wires for all that DC current. They basically rewired the entire trailer.
With that rig we could run our single AC for a couple of hours, though that's not something we often did because it hits the batteries hard - they get quite warm with that kind of draw for that period of time.. More importantly for us, this setup enabled us to dry camp indefinitely, aside from water concerns, without worrying about shore power. It also enabled us to moochdock in a driveway with only 15amp service and still run the AC from a mix of shore power, solar, and batteries, recharging the batteries from solar and shore power whenever the compressor wasn't running. That kind of moochdocking generates a pretty consistent load on shore power, so it's a good idea to make sure your host's outlet can actually handle whatever maximum amps you set your system for before doing that.
We're repeating this configuration now in our new-to-us Airstream Interstate van, with 400 watts on the roof and a configuration inside that's similar to the one we had installed in our trailer. This time we're using a pair of 200Ah LifeBlue batteries and a smaller solar controller since there are fewer watts on the roof, but otherwise it's about the same. Given we have a propane generator built into our van that we can use in case of emergency, we saw no need to go beyond 400Ah for the battery bank, though newer all-electric class B campers are now coming with significantly bigger banks, sometimes a second alternator (though Mercedes frowns on this for their Sprinters) and no generator.
Happy hunting, and good luck. With the pair of BB batteries, it sounds like you are already on your way toward deciding to replace those two sad little 90watt panels and the less-than-optimal infrastructure Airstream installed to support them as well as your batteries. If you're serious about camping without shore power, you'll do the upgrades sooner, rather than later.
