Old 05-17-2020, 06:39 AM   #1
boldie24's Avatar
2020 22' Bambi
Wake Forest , North Carolina
Expanding Solar on 2020 Bambi 22FB
I have done some searching and have not been able to find a specific answer so if it exists, please forward and apologies in advance.
I just purchased a 2020 Bambi 22fb with the factory installed solar. I believe it has the 90w panel installed as standard. I also understand it is a Zamp panel.
My question is this, how many more panels can I add? Additional 90w panels, larger panels with greater charging power, etc.? Has anyone maxed out their Bambi/Sport 22FB and what did you install?
Thanks very much and excited to be a new member of the Airstream community!
boldie24 is offline   Reply With Quote
Old 05-17-2020, 12:31 PM   #2
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Welcome Boldie24. I can't answer your question on how many panels will fit, but I will give you a link to read about mixing solar panels: https://solarpanelsvenue.com/mixing-solar-panels/
Its important to carefully match the voltage and amps on any mixed panels to avoid potentially significant losses to charging capabilities. I have mixed panels on my 27' Airstream and found panels that were closely matched to maximize charging potential. https://www.airforums.com/forums/f44...ml#post2288336
I'll bet Waninae39 will be along to answer your specific question about solar on a 22' Airstream. I think he has found a solution to maximize solar on his 22'.
2018 GT27Q, 73 nights 12,177 miles, 600W Solar - 110kWh, PD4655L, 6V Batteries, Blue Ox, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, Propride, 400W Solar - 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(O+5200)
AirMiles is offline   Reply With Quote
Old 05-17-2020, 03:33 PM   #3
boldie24's Avatar
2020 22' Bambi
Thanks very much for the insight and links. I will definitely check it out. We plan on doing some boon docking out west and want to maximize what I can with solar knowing that we will probably need a generator as well. I also like to solar keeping power to the trailer for my security system while at the storage facility.
I will DM Waninae39 as well.
Thanks again.
Dinette table, bench frame, and cushions from 2020 Bambi 22FB nomadiclife Airstream Classifieds 0 11-16-2019 08:23 AM
Airstream expanding R&D lab perryg114 Airstream "In the News" 0 11-02-2017 05:31 AM
Airstream expanding AGAIN? DanB Airstream "In the News" 15 02-26-2016 07:56 PM
Expanding Factory Solar Here4TheBeer Generators & Solar Power 4 02-09-2016 11:02 AM
expanding foam insulation DinubaDave Exterior Restoration Forum 8 06-30-2005 08:19 AM
