09-13-2020, 02:29 PM
2019 25' International
Providence
, Senior Electrical Engineer
Exact brand/model of factory solar panels?
When we were in JC, I added another panel (OEM) to the system and wanted to do a 4th, but there was enough room for the 4th panel.
I'm sure they sell shorter length panels and I want to keep within the same family of panel/brand.
Does anyone know the EXACT part number and manufacturer of the OEM 90W panels that are on the roof as the factory solar option?
Thanks.
Chris
09-13-2020, 03:47 PM
2013 27' FB International
El Dorado Hills
That info should be stamped on the underside of your existing panels. Also, I've read where you should stick with matched panels. Reason is mismatched panels will fight against each other, the result being all panels will function no better than the least capable panel.
09-13-2020, 04:06 PM
2021 30' Globetrotter
East Northport
, New York
Removed from a 2018 Serenity
James
09-13-2020, 04:11 PM
East Northport
, New York
Disregard... That is an 80W panel I posted.
James
09-13-2020, 05:03 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Zamp 90 watt long panels are what the factory uses.
https://www.zampsolar.com/90watt-long-expansion
09-13-2020, 05:58 PM
Providence
Originally Posted by GMFL
Perfect, now to see if they make anything that family that is "shorter"....
09-14-2020, 09:09 AM
Phoenix
If anyone is interested, I have two of these coming off my new 2020 Globetrotter this week. It's being upgraded to 1,000 watts of solar, so they are no longer needed.
PM me if interested. I'm in Phoenix if local pickup. Thanks.
Mike
09-14-2020, 12:06 PM
Providence
Mike
If I had the room, I'd buy em......LOL.
09-14-2020, 02:48 PM
2018 23' International
Guilford
, Connecticut
Removed from our 2018...
Pop & Mimms - because our grandchildren say so
2018 23FB International Serenity "Pimm's Cup"
2019 Tundra
09-14-2020, 08:44 PM
2020 19' Caravel
Boise
, ID
I would Love them. I’m in Boise, any chance we can ship them?
02-19-2021, 12:13 PM
2021 27' Globetrotter
Malibu
Mike did you ever find a buyer for these? We are in Phoenix next week with a new 2021 Globetrotter.
02-19-2021, 12:42 PM
2018 25' Flying Cloud
Portland
, Oregon
500w fits fine on a 25’ with 600 possible by going over tank vents. I’m not sure where AS puts the panels to start with so maybe that’s the problem. Here’s mine for reference. I used Renogy Eclipse panels.
Mixing panels of different characteristics may not be optimum from an efficiency standpoint.
02-19-2021, 12:43 PM
2022 25' Flying Cloud
NCR
, Ontario
IMHO, you to first determine where they will go on the roof. allow space around so nothing touches.
Then look at all the models of panels and choose the most efficient form both (POLY and MONO)- The later refers to how the crystals is made( one tends to look blue, the other tends to look black
Solar efficiency gets better every year. look for newer panels vs cheaper old ones
02-19-2021, 03:36 PM
Phoenix
Yes, I did, the panels have moved on.
Mike
07-17-2021, 12:44 PM
farsid9
2019 30' Flying Cloud
Williamson
, New York
I tried to upgrade my 180w of solar by adding another 170w (Zamp). Had room in the plug-in bar. Now my AS (Sunexplorer) controller is not working! Not sure the fuse was happy...but I can't find where the fuse is! Any help - much appreciated!
07-17-2021, 03:44 PM
2018 27' Globetrotter
Mooresville
, North Carolina
If you find your DC Distribuion box, the solar controller is located there. see attached pic. The red wire coming from it to the positive battery buss bar has an inline fuse on it.
On my FB Twin, it is under the curbside bed.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
