Old 04-20-2024, 05:11 PM   #1
navychief01's Avatar
2024 28' International
Leonardtown , Maryland
Question EMS-HW50C + (2) paralleled Gens = E2 Open Ground
So today I installed an EMS-HW50C from Progressive Industries into our International. The install was a bit of a bear, working thick power cables was the worst of it. Anyway, checked and double checked all the connections and good-2-go! However....
...doing an EMS system check, I hooked up two Harbor Freight 3500W Predators (like a lot!) to the parallel adapter. Checked the Smart Plug before plugging in (blue light = good), but when I plug the Smart Plug into the Airstream, I get a blue + red light indicating an 'open ground.' Never had this happen before using the gens.
When I went into the airstream to read the EMS display, it displayed error code E2 (open ground - no ground wire connection) therefor the contactor is not engaging on the EMS to allow AC to flow.
How do I properly fix this issue? Do I have to use some sort of a N-G shorting plug between my shore power cable male end and the parallel adapter? Do I need one for a 50A and a 30A connection?
Thank you for the help.
navychief01 is offline   Reply With Quote
Old 04-20-2024, 06:15 PM   #2
I guess this is what is needed?
https://www.amazon.com/Southwire-Com...ct_top?ie=UTF8
Old 04-20-2024, 07:55 PM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Yup!
You answered your own question
Required on most EMS systems.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 04-21-2024, 02:18 AM   #4
Thanks for confirming! Nothing as frustrating as rechecking one's install, wondering if somewhere I disconnected a wire underneath the rabbit hole (behind distro panel) or some other self-induced failure. Nothing in any manual, whether for the generator or the EMS regarding floating/bonded ground. I guess I should chalk it up to a, "duh, didn't you know you needed this plug?"
Question. If running parallel, only one plug is needed and it doesn't matter which gen it is plugged into?
Old 04-21-2024, 07:03 AM   #5
1994 30' Excella
Mississauga , Ontario
That’s right. Either one. If you have a spare plug you can make your own with a jumper wire. Cheaper.
Al and Jean
TAC ON-3
Progressive Dynamics EMS-HW50C billrector Electrical - Systems, Generators, Batteries & Solar 11 10-03-2017 04:20 AM
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Ems-hw50c cwf Electronics & Connectivity 1 03-26-2015 03:58 PM
Two Honda 2000 gens? LRL Generators & Solar Power 113 01-08-2012 07:57 PM
Should I take my Gens on our trip? chaimemet On The Road... 9 05-17-2009 06:57 PM
