Old 08-02-2019, 10:42 AM   #1
Camping Dutchman
2018 33' Classic
Manchester center , Vermont
Easy start; use of Honda eu2000i with 50 amp classic
Hi all,
Just installed myself the easy start (micro air) on one of my ACís (13.5 k BTU) of my 2018 classic 33 ft. ( with solar panels). Still have to run the learning cycles when Iím finally on shore power, so have not tested it out. It wasnít too difficult after studying the wire diagram and watching a you tube that specifically had the airstream penguin II model. Taking my time it took me an hour. If I ever do a second one, Iím sure I can do it in 30 minutes. ( letís hope I did it right &#128513
My questions are about the use of my Honda eu2000i generator with this.
1) I have only two 20 amp regular outlets on my generator. One is used to have the generator bonding plug in it ( which I made myself)
2) my airstream has a 50 amp power cord. I donít have a 30 amp. power cord.
But I have dog bones that can go from 50 to 30 and another one from 30 to 20 amp. Can I just used them in series? I have to plug it into a Honda eu2000i that only has a regular 20 amp socket.
3) does one still use a surge protector or not anymore with this generator?
4) do you run the generator in eco mode or not?
5) when using the generator do you first start the generator and than connect to trailer?
When shutting generator off, do you first disconnect from trailer? And than turn off generator?
6) given that very limited addition amp power left after using AC, I will run my fridge and hot water off gas. However, what should I further turn off to shut down any auxiliary power use that might trip the generator? And how does one shut down any auxiliary power use? Breaker panel?
Appreciate any comments from this very knowledgeable forum.
Thanks in advance,
Menno
Menno is offline   Reply With Quote
Old 08-02-2019, 10:53 AM   #2
Mollysdad's Avatar
The purpose of the bonding plug is to fool a surge protector or GFI.
So if you don't use the surge, you can unplug the bonding plug.
As far a a daisy chain of dog bones, yes.
But you still only have 20 amps, or less depending on the generator.
The Honda 2000is has a continuous output of 13.33 amps. (16 amps for a short time)
That may be enough to run the AC, but not much more.
Don't forget the converter will eat 4 amps.
As far as plugging and unplugging, the preferred method is to turn off the appliance, then unplug, then power down.
However, after a lot of experience in using the Honda EU3000is, we just shut them down. We were using them for sensitive fiber systems and nothing ever failed. After all, the generator runs out of gas too.
Old 08-02-2019, 11:07 AM   #3
Wconley's Avatar
2018 28' International
Renton , Washington
Welcome to the Easy Start club. I installed mine myself as well to our 13,500BTU unit. I installed one of these adapter plugs to minimize the number of connections where heat can build up due to losses. Then all you need is a good extension cord from generator to where this plugs into your trailer. But if you want, you can just go through your multiple adapters.
If Iím going to run the AC I take the generator off of eco mode just to stabilize the power but I have confirmed the Honda will react quick enough to power the AC. When we installed our solar and lithium batteries the converter was replaced with a Victron unit that draws much more power than the OEM one that Airstream uses and Iíve found that if the converter is charging the batteries I cannot run the AC at the same time with our Honda 2000 so I have to turn off the converter.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 08-02-2019, 11:09 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I start the gen and then plug it in. I do not think it matters much. I have to turn off my power converter to run the AC. The batteries are usually low and a big converter draws a bit of power. Maybe 6 of your avaliable amps. With fridge and WH on propane that is the only big draw left. Our trailer has the converter on a switched circuit. If yours is not maybe the breaker will work as a switch for it. I only run the AC on gen when it is pretty hot outside so I turn it to full cold. That keeps the compressor running and it only has to start once,
Old 08-02-2019, 11:33 AM   #5
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Just as a footnote: I bought a 2200i honda after my 2000i got a little tired. It runs my 15,000 btu AC with Easystart and converter with ease. I changed the carb in the 2000i and it came back to life. The Carbs are only $79.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 08-03-2019, 06:57 AM   #6
Camping Dutchman
2018 33' Classic
No need for EMS with use of generator
Reply; Thanks for that. I did a bit more research and found this interesting link where the use or not of an EMS is discussed including the use of the bonding plug. Basically the short version of it is; ďthe generator is not capable of producing "high voltage" conditions, so an "overvoltage situation is unlikely (unless lightening strikes your system) and the generator also has a "low voltage" (overload) monitor circuit and will shut itself off, which is the same function as the "low voltage monitor" in your line monitor circuit within your surge protector.Ē Full link http://www.keystoneforums.com/forums...ad.php?t=26147.
Now, I hope that all this is correct and I donít put facts out that are not true. So please correct me if necessary,
Old 08-03-2019, 02:07 PM   #7
1985 31' Excella
st. Paul , mn
Originally Posted by Menno View Post
Hi all,
Thanks in advance,
Menno
What is going on with all this magic thinking ???
Honda 2000 is 2000 watts surge , 1600 watts continuous .
2 - 20 amp outlets , Ohms law - 20 amps x 120 volts = 2,400 watts x 2 = 4,800 watts ?????
Now throw in jumping from 30 amp to 50 amp - use some basic math ----- not magic thinking !
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 08-03-2019, 03:15 PM   #8
2019 30' Classic
Belleville , Illinois
A word of caution using a dog bone to adapt from 30 amp service to a 50 amp cord with a surge protector in between.
I connected 30 amp service to a 50 amp surge protector via dog bone. Then from surge protector to AS using 50 amp cord. In essence that changed 3 wires from the house breaker panel to 4 wires into the AS. That extra wire electrified my chassis so that when I touched, for example, the metal near the drain valves on the fresh water tank it shocked me. I am no electrician but was told the extra wire had no where to go so it was like an extra ground. When I removed the surge protector and the dog bone and went straight 30 amp to the AS the shock ceased.
Presitla99 is offline   Reply With Quote
Old 08-03-2019, 03:53 PM   #9
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Be aware that AC motors are more finicky on power quality and use, unlike straight resistance heaters. The A/C motors like all motors require watts to power up. However, in AC circuits you still need to deal with real and reactive loads. This translates to KWATTs and KVARS. It simply means to us that the motors use more power than indicated therefore, possibly making the genny rating inadequate. Power factor, if you please. That's why its good idea to have SoftStart an a little extra capacity.
guskmg
Old 08-06-2019, 04:50 AM   #10
2018 30' Classic
Callao , Virginia
Turk, do you use propane? I have the Easy Starts with EU2200i and Hutch Mountain propane adapter. Mine gen kicks out on overload after a few minutes running one AC
Airhead2018 is offline   Reply With Quote
Honda EU2000I Generator and EU2000I Companion Mldun Airstream Classifieds 0 03-29-2018 10:51 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
What oil do you use in your Honda EU2000i? barrettjl Generators & Solar Power 11 07-03-2012 09:26 AM
Honda EU2000i won't start NO Spark sommay Generators & Solar Power 10 06-07-2010 01:35 PM
