Old 03-13-2020, 11:03 AM   #61
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by Milo1952 View Post
Just purchased 2 Lion Ut1300 lithium.
I need to upgrade my charger.
Any suggestions to which one I should get ? These are group 24 size.
Other than the charger is there anything else I NEED to do ??????
Plan on using an Renogy 200 watt suitcase or Zamp 230 w. suitcase.
You should disconnect the charge wire from the TRAILER side of the umbilical, not the tow vehicle side. From what has been said at best the tv will drain the lithium batteries while towing, at worst damage them. From the trailer side since if you break down you may forget or might not be able to get the tow driver to disconnect the charge wire on his vehicle.
Old 03-13-2020, 11:41 AM   #62
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
This is a relevant point. Definitely worth discussing with the folks from whom you buy any drop-in lithium battery replacements for your lead acid units (e.g. Battle Born).
I had a PM asking about what charger to use if one swaps in drop-in Lithium battery replacements for the lead-acid batteries on the tongue. Several threads here discussed that topic previously. Some of them also discuss the charging issue between truck / trailer and how to manage it.
Full disclosure we did an extreme version of this upgrade, having AM Solar rip and replace our entire electrical system to go full-on lithium / solar, so when it comes to details for a less-extreme upgrade, I may sometimes be fuzzy. On the other hand, here are a couple of relevant threads that provide quite a few specifics relevant to DIY-ers. There are other threads as well, easily found by searching the forum for "lithium charging".
Old 03-14-2020, 07:01 AM   #63
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Ok so to be fully accurate:
You need to locate the wire that runs from the tow vehicle alternator and battery back to the 7 pin connector and goes via the 7 pin connector to the DC wiring harness to the DC bus distribution block in the trailer. That wire needs to be disconnected at the DC distribution bus.
Or you can put in a DC/DC converter and solve the problem another way.
Old 03-14-2020, 12:51 PM   #64
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
What is the problem being solved...🤓
Will damage them...How? 🤔
Maybe not sync them or top to 100%, but drain them?
7k cross country & 2 yrs use has not happened yet.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 03-14-2020, 06:42 PM   #65
2020 27' Globetrotter
STAMFORD , Connecticut
Hi
Caution: This is very likely dependent on how the tow vehicle manages the +12V connector pin#4. For example, when the tow vehicle is running, it likely sends current "out" the 7-way connector to the trailer. However, when the tow vehicle is not running, it may open a relay on that specific #4 pin and therefore prevent back-feeding from the trailer battery bank. You have to check how your two vehicle behaves and manages that pin before summarily disconnecting or modifying it.
Justinfinity is offline   Reply With Quote
Old 03-15-2020, 10:37 AM   #66
ed , Alberta
Why would you purposely choose a DC fridge for boondocking? They're not meant for that. Theyre meant for RV parks.
Should have bought a good three way fridge.
Gcragg is offline   Reply With Quote
Old 03-15-2020, 10:40 AM   #67
Rocinante's Avatar
I disagree with this assertion. With a good solar system and a decent set of lithium batteries, a DC fridge with a Danfoss compressor is absolutely the best choice.
Old 03-15-2020, 10:59 AM   #68
ed , Alberta
I disagree. Adding an 8 or 10amp draw when its not necessary is not smart Boondocking prep. A couple of 30lb propane bottles will run a fridge for months. And its cheap.
Also. Not everyone is Boondocking in climes where solar is that reliable. Cloudy days, snow etc can make solar very unreliable. And Ill do all I can to avoid running a gen.
So I guess it comes down to personal preferences and getting a setup that works for you. But lets face it. DC fridges where not designed with boondockers in mind.
And it pisses me off when manufacturers start forcing them on you by factory installing them.
Old 03-15-2020, 11:18 AM   #69
Cum on guyz...
Hi
You'yall...got me grey cells so hot I had to hitch up and do a run.😡
Burb@1200rpm, 58mph, 8mi run....🤔 ...........post run@rest,unhitched.
ID:	363312   Click image for larger version
Molly Ivins
Tahawus
Old 03-16-2020, 06:52 AM   #70
Half a Rivet Short
Hi
The relay in the TV is never going to be smart enough to know which way current is flowing. It simply closes a circuit. That's all a relay does. If the voltage in the trailer is higher than the voltage in the TV, current will flow from the trailer to the TV. That's just basic electricity stuff.
Lithium's like to be up above 13.6V and lithium chargers run up to 14.x V. Your vehicle electrical system in the summer *should* idle around 12.5 to 13.2 volts. If it's higher than that your battery isn't going to last very long. If it's lower than that, the battery won't get / stay fully charged.
The voltage difference is what gets the lithiums bothered when you hook straight from one system to the other. Running down the road vs parked, either way, it's an issue.
Old 03-16-2020, 04:43 PM   #71
1988 32' Excella
Don't know, maybe near complete discharge?
Possibility of damage was mentioned in other threads so I mentioned that it could be a worst case scenario.
Old 03-16-2020, 06:00 PM   #72
Our TV has no relay...so the little 'letric buggers can go anywhere they choose and wherever they went hasn't caused any concerns in 7500mi+.
Never mind...🤓
Molly Ivins
Tahawus
Old 03-17-2020, 02:46 PM   #73
1. It doesn't matter what your charge source is or how powerful it is, the declining Charge Acceptance Rate (CAR) inherent to lead acid and AGM battery chemistries means that you will always have to dedicate more hours of charge time getting the batteries from, for example, 85% to 100%. Lithium batteries don't have this issue. They'll take all you can supply until they are at 100% and they'll do it much faster.
2. Over their life and the energy produced, Lithium batteries are less expensive than lead acid and AGM batteries. The up-front capital cost is higher but the cost per unit of energy over time is lower. Lead acid batteries are like like cheap shoes: they are a false economy.
Old 03-18-2020, 08:05 PM   #74
Long Island , New York
. . . Lead acid batteries are like like cheap shoes: they are a false economy.
In all climates and weather conditions?
What about the fact that you can charge those old-fashioned batteries in temperatures below freezing? Not so with lithiums, right?
Our Airstream sits in the back yard all winter, where we can keep the batteries charged with careful periodic shore power. Works for us!
Do you have lithium batteries installed all winter in Connecticut, and if so, what do you do about keeping them topped up all winter?
Peter
Old 03-19-2020, 03:24 AM   #75
1. Lithium batteries don't need to be "topped up" because there is no sulfating risk as there is in conventional lead acid battery chemistries.
2. A lithium battery with a good BMS will manage and protect the battery according to temperature, voltage, and current.
3. A lithium battery does not need to be kept charged in freezing temperatures when in storage. However, if you wish to charge or "top up" a lithium battery in freezing temperatures, then a heat source is needed to get the battery up to a temperature at which it is safe to charge. Some installations have external heat wraps which are managed separately from the battery. Some batteries have heating pads built in and are managed by the BMS. In the latter category, when a charge source is available, the BMS will direct the external power to the heating pads and only then start charging the battery when it is safe to do so. An example of a battery that does this is LifeBlue low temperature models (this is what I have).
Old 03-19-2020, 05:45 AM   #76
Thumbs up
Thank you for those details.
Peter
Peter
Old 03-19-2020, 12:01 PM   #77
Bacliff , TX
Cold weather lithium batteries
Technology is moving faster than outdated information. RELiON has developed a new series of lithium iron phosphate batteries that can charge at temperatures down to -20C (-4F). They are not the only company offering low temp lithium batteries.
Also, the self discharge rate of a lead acid battery (AGM,SLA,flooded) is about 4% per week or 15% per month. So if you store for 3 months you can lose 45% capacity - basically have 5% usable Ah in the battery- based on 50% max recommended discharge. Lithium batteries self discharge at 2-3% per month. So in the same 3 month period, you lose 10% capacity and still have 70% usable amp hours in the battery - based on an 80% max discharge, although you can discharge to 100%.
Also, The energy available at low temperatures is higher in lithium batteries than in lead acid. At 0C, for example, a lead-acid batterys capacity is reduced by up to 50%, while a lithium iron phosphate battery suffers only a 10% loss at the same temperature.
jimdelane is offline   Reply With Quote
Old 03-19-2020, 12:41 PM   #78
Thanks for that info. Good to know about the low-temp lithium option.
As stated, however, we keep our OEM batteries charged during the winter with careful use of shore power, and we monitor water level etc.. For now this low-cost option works for us.
Peter
Peter
Old 03-20-2020, 06:34 AM   #79
Ask the folks in Minnesota about battery heaters.
Even installed a few here in WNY.
BB has had them for sale from the start.
Molly Ivins
Tahawus
Dometic refrigerator wont run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 22 04-10-2018 02:57 PM
Batteries not charging via shore power??? crazylev Electrical - Systems, Generators, Batteries & Solar 29 08-30-2016 08:35 AM
Battery charging when connected to shore power. Wingeezer Batteries, Univolts, Converters & Inverters 3 07-15-2011 10:12 AM
Charging battery on shore power. Dr Dan Batteries, Univolts, Converters & Inverters 8 08-26-2010 02:07 PM
Charging Battery While Plugged in to Shore Power Kevin245 Batteries, Univolts, Converters & Inverters 2 12-29-2007 01:10 PM
