10-06-2018, 10:03 AM
2019 30' Classic
Canfield
Compressor not running AC - Easystart HELP
Just did an install for my easystart and I have a problem. Compressor won't start.
My 2019 classic has a purple wire running off the black run cap to the compressor. That wire is not shown in any of the diagrams I've seen. All show a red and a white wire. This may be the problem.
If anyone has some ideas, please let me know. I have it all apart and Micro air is closed.
HELP
Tom & Doty
10-06-2018, 10:29 AM
2018 25' International
Mound
Are you saying there is an extra wire or just one with a different color than you are expecting ? A photo or two might help tell how it is connected.
10-06-2018, 10:32 AM
2019 30' Classic
Canfield
The start cap (small black one next to the large one) has three wires. Red white and purple. Purple goes into compressor.
Tom & Doty
10-06-2018, 10:34 AM
2019 30' Classic
Canfield
I've got to get my terms down, but the two pieces that get removed in the instructions have this third extra wire. I removed it from the top of the cap, but it has nowhere to hook in the instructions. Just taped the end.
Tom & Doty
10-06-2018, 10:36 AM
2019 30' Classic
Canfield
None of the diagrams have shown this wire. It must be new for 2019 and who knows what it does?
Tom & Doty
10-06-2018, 10:37 AM
2019 30' Classic
Canfield
Does anyone have Mateo's number? His old cell phone number is disconnected.
PM Me.
Tom & Doty
10-06-2018, 11:02 AM
2018 28' International
Renton
Use the Support Contact page for Micro Air and they will respond quickly. I had a problem and sent pictures of my wiring and the next morning Mateo had responded pointing to my problem. They were great! They followed up with a couple of other emails to make sure everything was working correctly. Great people.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
10-06-2018, 11:43 AM
2019 30' Classic
Canfield
They are closed.
Was told by someone here to connect purple wire to "c' terminal of the large silver cap.
No go : (
Tom & Doty
10-06-2018, 01:57 PM
2002 30' Classic S/O
Fleming Island
Have you looked on line for instructions or are you just using the ones that ship with the EasyStart? There are better diagrams on line.
Al
10-06-2018, 02:52 PM
2019 30' Classic
Canfield
Al
I have three diagrams. The purple wire is not on any of them.
Everything runs except the compressor never comes on. There must be something different about this unit and that purple compressor line.
Tom & Doty
10-06-2018, 03:02 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Can you post a pic of the wiring diagram from your ac?
I bet Al can figure it out.
10-06-2018, 07:45 PM
2019 30' Classic
Canfield
Interestingly Airstream has never given me schematics or even a manual for the air conditioner. Same with my last trailer.
Tom & Doty
10-06-2018, 08:28 PM
2007 31' Classic
Gulf Breeze
Contact Matteo at Micro Air Easy Start
10-07-2018, 05:17 AM
Somewhere
, South Carolina
Have you taken the AC shroud off an looked for mfgr schematic on unit?
10-07-2018, 05:43 AM
Somewhere
, South Carolina
I downloaded a manual for mine a while back and it does have the wiring schematic in it. And this link might help you find PDF version of yours.
http://https://www.dometic.com/en-us/us/support
Dometic support.
10-07-2018, 06:36 AM
2019 30' Classic
Canfield
I went to the Dometic site and I did find the model I have. It also has the schematic I've posted here. It HAS the purple wire!
Any Ideas?
Tom & Doty
10-07-2018, 06:44 AM
Somewhere
, South Carolina
I’m sure others will chime in too. I installed ONE easy start and IIRC followed their diagram. At start up it did not run on air cond.
I stripped wires off to match ES diagram, went back on dometic diagram and I had removed and not reconnected the reversing valve common wire which on your diagram is BLK or WHT/PRP.
Is your wire wht/prp or prp?
10-07-2018, 06:52 AM
2019 30' Classic
Canfield
Purple. I was told by someone to hook the purple end to "C" on the run cap. Is that correct?
Tom & Doty
10-07-2018, 07:30 AM
Fleming Island
Purple to C on RUN looks right to me. Without that connection it the compressor should have run, but only if the thermostat was in heat mode and set for a temperature higher than ambient.
Hook it up, it doesn't look like it can hurt anything. C on all terminals is the white wire which is line neutral as best I can tell.
Al
10-07-2018, 08:09 AM
2019 30' Classic
Canfield
I have it on the "C" run cap but that does not allow the compressor to run.
I know that the Easy-start can be sensitive to low power, but I'm on 50 amp and shore power seems fine.
Tom & Doty
