Old 03-26-2020, 09:04 AM   #1
Charging Goal Zero with Zamp
Hey all. Using a Goal Zero Yeti 1400 as backup power when I boondock with my AS. I already have a Zamp Solar brief case that I plug in to my Zamp port when the sun doesn't hit my fixed panels. Anyone know of a way to use the Zamp Solar Brief Case to charge a Goal Zero Yeti 1400. The panels use an SAE connector but the Goal Zero doesn't. The Zamp panels also have a built in controller. Could I bypass it and is there an adapter I could use that would be compatible with the Yeti's ports? Thanks in advance for any thoughts you may have to enlighten me!
steilkurve is offline   Reply With Quote
Old 03-26-2020, 11:41 AM   #2
Long Island , New York
You might want to read this thread, and ask there IMO:
https://www.airforums.com/forums/f24...-a-178647.html
Pahaska seems knowledgeable on GZ issues IMO.
Good luck,
Peter
Old 03-26-2020, 11:43 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
You should be able to find it here. it depends what receptacle the GZ has. I believe it's the first one.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."Molly Ivins
“Growing Old…being able to think about the things you can no longer remember.” RLC
"Never tow faster than your Guardian Angel can Fly"
Tahawus....🌥
Old 03-26-2020, 03:38 PM   #4
Thanks. I didn't know polarity inverters existed. Novice here. I would still need to add a converter to the appropriate port on the Goal Zero and find a way to bypass the converter built into my Zamp panels but now I have one piece of the puzzle.
Old 03-26-2020, 04:59 PM   #5
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
ZAMP tech told me that I would need to abandon the controller on my ZAMP 140 and feed directly into my Goal Zero 400 since the 400 has it's own controller. Goal Zero tech seemed dubious of that solution. Also, it would void the ZAMP warranty.
I use my RAM 2500's AC outlet to charge my GZ400 while driving.
I also use my 25FB's AC outlet powered by the inverter batteries charged by 500 watts of solar on the roof, when boon docking.
I was hoping to use the ZAMP 140 to power the GZ 400 while dry camping in the 68 Caravel. I'll stick with charging the GZ400 in the RAM while towing the little vintage.
SilverWind is offline   Reply With Quote
Old 03-26-2020, 05:43 PM   #6
Try it...if there is a problem the Zamp Suitcase Controller will show a fault code and open the circuit.
AMHIK...I did my own fly-by-night suitcase wiring, it bailed me out several times.
Tahawus....🌥
Old 03-27-2020, 09:35 PM   #7
Sheridan , California
I use an 80 watt Zamp panel to recharge a Goal Zero Yeti 400. There's an Anderson port on both sides of the Yeti that bypassed the Yeti's built in controler. Zamp panel automatically shuts off when Yeti is fully charged.
Airabel-2 is offline   Reply With Quote
Old 03-28-2020, 06:23 AM   #8
Interesting. That would mean you have an SAE to Anderson adapter. Does it reverse polarity as I understood Zamp’s was switched?
Old 03-28-2020, 01:47 PM   #9
I use an SAE to Anderson pigtail. Just make sure red side on Anderson plug is connected to positive side of the SAE plug and Zamp . One issue with doing this is the input-output gauge on the Yeti does not indicate a charge while the Zamp is charging the Yeti. Zamp controler will indicate it's charging and will stop when Yeti is fully charged. If you check the Anderson terminals with a multimeter it will show the Yeti battery is fully charged.
Old 03-28-2020, 02:00 PM   #10
One other thing I forgot to mention. On the Zamp controler, make sure you set the type of battery you are charging. My Yeti 400 uses an "AGM" while the trailer battery is "WET".
There's a button on the controler to set battery type.
Old Yesterday, 02:49 PM   #11
SilverWind's Avatar
1968 17' Caravel
I noticed that you mentioned that your Yeti 400 is an AGM. My 400 Lithium does not have Anderson inputs, only a female 8mm input .
I'm considering purchasing this Anderson to 8mm male adapter. https://www.amazon.com/gp/product/B0...VP3AMH26&psc=1
I already have an adapter with that particular Anderson end mated to an SAE connector with a polarity reverser, to 7pin trailer connector. I use this setup for my ZAMP 400 to 7pin trailer connector on my 68 Caravel.
My only concern is whether this particular 8mm male is compatible with the Yeti female. Does anyone happen to know?
Old Yesterday, 03:31 PM   #12
SilverWind's Avatar
1968 17' Caravel
Also, my ZAMP 140 is of the newest generation which auto senses lithium batteries like the one in my 400 Lithium. I'm hoping that this capability will negate the need to bypass the ZAMP's controller.
« Solar Show and Tell | Top | - »
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
KC5ME
Goal Zero Yeti 400 Lithium - ZAMP 140 Solar SilverWind Generators & Solar Power 3 03-26-2020 03:45 PM
Goal Zero YETI LINK CAR CHARGING KIT coasttocoast Electrical - Systems, Generators, Batteries & Solar 1 10-15-2019 05:00 PM
Goal Zero Lighthouse 250 LED Lantern pappy19 On The Road... 17 12-31-2014 01:49 PM
AimZero- zero grid, zero feul, zero discomfort, zero nonsense. greenlinks Off Topic Forum 14 01-03-2014 08:13 PM
