03-02-2022, 05:59 AM
2017 27' International
Somewhere
, Any State
Champion 2500W Dual Fuel Performance
Looking for thoughts/comments from owners on the performance of the Champion 2500w Dual Fuel Generator.
We have a 2017 27FBT with a single 15K a/c and a Micro Air Easy Start installed and want to know how the 2500w Gen will perform as a back-up power source when shore power isn’t available.
I plan to run the Gen on propane only and am most interested in knowing if the 1650 running watts (on propane) would be adequate to run the a/c in a pinch.
I am also considering the Champion 4500w dual fuel, but trying to avoid the added weight, noise, cost, and space requirements for a back-up power source.
Any insights is appreciated.
“The Journey is the Reward”
BRN 22801
2017 Int 27FBT
2010 GMC 2500HD
03-02-2022, 07:15 AM
2020 27' Globetrotter
Greater Salt Lake City
, Utah
Happened to watch this the other day……..might be helpful for you.
https://youtu.be/WEvAM69-nrs
Steve
03-02-2022, 10:09 AM
Rookie
2022 20' Basecamp
Falls Church
, Virginia
We have the 13.5k a/c on our unit (no Easy Start) and run it with the Champion 2500w using propane. No problems starting up or running the a/c. Love the portability and size of the 2500w generator.
Edit: If you go this route, be sure to use a 20amp adapter plug - not the standard 15 amp adapter - to get the most out of the output power.
03-02-2022, 10:19 AM
2020 23' International
Evergreen
I can’t speak about the 2500, but I own the 4500 and it’s great. It provides enough power to run everything, in all conditions, without question. It’s quiet and it will run for 14+ hours on a tank of gasoline under moderate load. It works well at high altitude. The trade off is obviously the size and weight, but it rides in our truck bed and it’s no big deal. It has big handles and can easily be lifted in and out of the truck bed by two people, and I can handle it alone if necessary.
Dennis
Previous: Airstream International Serenity 23 FB
Current: Newmar Ventana 3715
03-02-2022, 10:38 AM
2022 28' Pottery Barn
Ż\_(ツ)_/Ż
I was definitely interested at the price point, but am not sure that you simply don't get more power (running and CCs), easier start and reliability with the Honda eu2200i (although at 2x the price!)
This video is helpful for the Champion 2500 as well:
https://youtu.be/g6b_9kQ_l_g
03-02-2022, 02:49 PM
Somewhere
, Any State
Thanks for the thoughts on the 4500 very helpful. I like the idea of the small, light weight 2500, but know the bigger, heavier 4500 would serve all my needs with no issues. Perhaps I am over thinking the size/weight issue of the 4500.
BRN 22801
2017 Int 27FBT
2010 GMC 2500HD
03-02-2022, 03:03 PM
Evergreen
You could always get the smaller generator and try it. If you need more power, then add a companion generator and a parallel connection kit. Then you’d have two small generators that provide the power of one larger generator. Overall weight would be similar, but it would be in a more manageable form.
I found gasoline to be easier to manage for generator fuel than propane, so I stuck with the gasoline unit. I contacted Champion and they sent me a high altitude (6,000+ feet) carburetor jet at no charge. Most of my camping is well above 6,000 feet, which is another reason that I wanted the larger unit. Internal combustion engines lose 3 - 4% of their power for every thousand feet of elevation above sea level.
One final note - remote start is worth it! It’s nice to be able to just push a button from inside the Airstream and fire up the generator.
Good luck with your decision!
Dennis
03-02-2022, 08:12 PM
Ż\_(ツ)_/Ż
I like the 4500, but it looks like the dual-fuel does not come with remote start and it may be about 1/2 inch too high to fit under my Retrax in the TV bed.
03-02-2022, 08:47 PM
2019 30' International
Pennsylvania
, Pennsylvania
I bought two Champion 2500 dual fuel and the parallel kit.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
03-02-2022, 09:53 PM
Evergreen
The 4500 fits under the Retrax on my GMC.
I originally planned to buy the 3400. When I researched it, I found that the 4500 would fit in my truck bed under the Retrax cover, it only weighs 6 lbs. more than the 3400, and it cost less. It was an easy decision.
Dennis
03-02-2022, 10:04 PM
Ż\_(ツ)_/Ż
I have a Ram HD 2500 with a bed liner, which likely has different clearance below the Retrax than does your GMC 1500.
The tape measure does not lie, the 4500 will be too high.
03-02-2022, 10:21 PM
Evergreen
Got it. It’s close in the GMC, but it works.
Dennis
03-03-2022, 06:37 AM
Somewhere
, Any State
I have a GMC 2500HD as well and it looks like the 4500 would fit under my bed cover with about 1/2 of clearance.
As for buying two 2500 with the parallel kit, not sure that be the best option if the intent is more power. 2 x 2500 would cost more, twice as much maintenance, more space needed, and about the same weight. Just not confident that one 2500 would meet my minimum power needs.
BRN 22801
2017 Int 27FBT
2010 GMC 2500HD
03-03-2022, 06:41 AM
Somewhere
, Any State
Thanks for you insights. I have considered the 2 x 2500 option, but if I think more power would be desired, I would likely go with the 4500 for simplicity.
BRN 22801
2017 Int 27FBT
2010 GMC 2500HD
03-03-2022, 07:47 AM
Kildeer
I have the Westinghouse iGEN 4500 with Duel Fuel/electric start/wireless remote start that works great. Very quiet as compared to others in its class. Full LED display of all parameters. It fits perfectly under the tonneau of my F250 with the thick bed mat. Just another option.
2022 Ford F250 Platinum - PowerStroke Diesel
9 Other vehicles unrelated to RV's.....
03-03-2022, 10:30 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
We have to "old" 3500 dual and love it - run it in the back of the F-150 was the best gen we have ever owned
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
03-03-2022, 10:38 AM
Antes Fort
, Pennsylvania
I have a Champion 30 Amp duel fuel it works great. Always used propane.
03-03-2022, 11:07 AM
2019 30' Flying Cloud
COLUMBUS
, Ohio
I have the Champion 3500 but instead of the dual fuel I purchased the external fuel kit from Pinellas Power Products, https://www.pinellaspowerproducts.com/ for the remote start generator. I think that's a better way to go than dual fuel. Based on my experience with this generator I'd probably always opt for the external fuel tank over the dual fuel. Gasoline is easier to come by than propane. Gasoline has a higher power density. With the external fuel tank I have run the generator & my air conditioner for over 14 hours non-stop, ie.e overnight, without having to get up to screw with the generator.
03-03-2022, 11:29 AM
2014 25' FB Flying Cloud
Yuma
I have that exact generator. I run only on propane. At sea level it is adequate but at above 1500 ft it will struggle with more than AC powered up. Running charger and AC at same time causes shutdown. I run off LPG port on 2014 FC FBT. Also, hard to start. 20-30 pulls. If I had to do it over again (and I might) I would look at other options. Electric start 4500 watt comes to mind. Mine is for sale.
03-03-2022, 12:16 PM
Evergreen
One more comment I’ll add is that if you choose to go with a gasoline powered generator, then consider using TruFuel. It’s pure gasoline without ethanol, additives, detergents, etc. It can be stored for years and it won’t gum up the carburetor or fuel system like pump gasoline does. It’s expensive, but it’s worth the price in my opinion. I buy it at Home Depot.
Dennis
