Old 12-12-2024, 09:23 AM   #21
2020 25' Flying Cloud
San Antonio , Texas
Originally Posted by BikeCamper View Post
I’ve seen it enforced by campers. On more than one occasion a nearby camper has just walked over and hit the kill switch on an overly noisy generator. That could be a tragedy if your dogs are in the trailer relying on the a/c to keep them cool.
I have been a camp host at Tortilla Campground, Tonto National Forest for the past 5 seasons. The US Forest service has very liberal generator hours 6 a.m. - 10 p.m.. We cannot control the type of generator, but we do enforce the rule violators. If they don't comply, we get LEO's (law enforcement officers) to remove them. We NEVER touch campers' equipment.
SpeedBump is offline   Reply With Quote
Old 12-12-2024, 10:30 AM   #22
19’ Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
That seems like a smart policy. Like I said, I wouldn’t mess with someone else’s property except in a dire emergency (eg, fire, life-threatening situation, etc.), and then only if LEO/first-responders are not available in a timely manner.
2017 Bambi 19 Flying Cloud
BikeCamper is offline   Reply With Quote
Old 12-12-2024, 10:32 AM   #23
BikeCamper's Avatar
Originally Posted by Lvanden View Post
Thanks for all the great feedback. Final decision...Champion 2500 Dual Fuel for the weight along with the 30Amp parallel connector (so I don't have to double dog-bone). I think it gives me the flexibility to add another generator if needed (I don't think I will) and it makes connecting to the RV 30Amp with just the single dog bone easier.
This is a great forum, thanks for all the feedback and suggesions.
That sounds like a good choice. There are many very satisfied owners of that generator on this forum. Keeping weight manageable is always smart.
Old 12-13-2024, 01:52 PM   #24
R.U.N.N.O.F.T.
Runnoft's Avatar
2019 27' Globetrotter
Bethesda , Maryland
Originally Posted by gypsydad View Post
I have the regular Honda 2200 Propane model, from Genconnex. Very happy. I believe the only difference is the Companion model has 1- 20A, and 1-30A outlets, and the model I have has 2-20A plug's. The Companion is $100 more for some reason. Both have Bluetooth. I use one to run my AC when needed or as backup to charge batteries. I do use a 20A-50A pigtail from the Honda to the AS when I use. With Li batteries now, did not use the Honda this year. Just sits in the back of my truck bed, when/if needed.
We have same setup, but I went with the Companion 2200 to eliminate one of the dog bones. We have 50 Amp GT. Works well, never smells since we are burning propane, can keep in back seat of my truck, if necessary, when not in use. Runs either AC. Easy Starts installed, of course. Would NEVER look back on my choice of this setup. Gets rid of gas can and the exhaust smell when not in use.
OF NOTE: this setup will run perfectly off the low pressure propane port at the front of the Airstream no problem. I have a friend with larger generator that will NOT run off that port. So if you go for bigger and heavier than a 2200, you can’t really do much more with it, and you have to disconnect one of your tanks hoses to connect up to your generator. Just keep in mind more trade offs you may not be aware of when selecting these things.
Runnoft is offline   Reply With Quote
Old 12-13-2024, 05:27 PM   #25
2019 25' Flying Cloud
Houston , Texas
I've seen people say this before, but I don't understand it. I have a 20 amp to 50 amp adapter so just one.
DCPAS is offline   Reply With Quote
Champion 3400 watt dual fuel inverter-generator Milo1952 Generators & Solar Power 27 07-22-2021 09:05 AM
Champion Dual Fuel Generator - What do you think? trekerboy Generators & Solar Power 40 01-16-2018 11:41 PM
Champion 3400 Dual Fuel $937 Today Only AirMiles Generators & Solar Power 99 11-01-2017 10:10 AM
Champion Dual Fuel Generator SilverSinbad Generators & Solar Power 2 05-12-2017 04:48 PM
