Old 02-04-2020, 05:08 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
Can Two Solar Suitcases be used at same time?
I have one of these dual solar plug inputs installed on the battery box of my batteries. I currently only use one input for my Renogy Solar Suitcase (has its own charge controller.) However, a friend is offering me his Solar Suitcase .. so could I connect both of them at the same time? Would they each monitor the battery, would there be any conflict the with two independent controllers?
Name:	Double Input.jpg
tjwoods1 is offline   Reply With Quote
Old 02-04-2020, 06:37 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I have two Renogy 200W solar suitcases through one controller (Victron 30/100). I have not had both camping yet, but after some experimenting, they are working fine. I made the double connection using a cable combiner that I made, so it goes two series suitcase connections into a parallel connection back to the controller. If you want some schematics, PM me.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 02-04-2020, 07:33 PM   #3
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
I have 200 watt on the roof and 160 watt suitcase which I connect directly to the battery with its own controller. I often run both sets of solar panels because usually the solar panel system on the roof of the Airstream is not necessarily in the sun all the time where we camp. The suitcase gives me the option then to track the sun with direct charging to the battery we have used this system continuously works fine maintains the batteries beautifully.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 02-04-2020, 07:40 PM   #4
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
I have 300 watts on the canopy of my truck that I connect with a 25 ft umbilical. I have a Y connection on the end of the cable from my Renogy 100W suitcase that I can plug into the connection at the front of the trailer giving the ability to take advantage of any sun available when camping under tree cover here on Vancouver Island. Works great.
gandttimes is offline   Reply With Quote
Old 02-04-2020, 09:10 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes...2 180w Zamp
ID:	360551   Click image for larger version
Old 02-05-2020, 12:52 PM   #6
Eugene , Oregon
Thanks for the feedback- looks like it will work just fine.
Old 02-06-2020, 10:03 AM   #7
Brookhaven , Georgia
Google powerwerx.com
coasttocoast is offline   Reply With Quote
Old 02-07-2020, 12:46 PM   #8
2014 27' FB International
Clearwater , Florida
A qualified yes. My 2014 did not have a connector to use. I added a Anderson 50a polarized connector direct wired to the battery. Used the Renogy charge controller supplied with my first set. When adding the second panel without controller I purchased a 30a charge controller. Using 10ga garden wire and anderson connectors I made a “Y” connector and extension cord to allow separate panel placement and the choice of parallel of series connection. I can park in the shade and place panels in the sun.
ChuckFeldt is offline   Reply With Quote
Using 2 Solar Suitcases tjwoods1 Generators & Solar Power 6 01-09-2019 09:56 PM
Use Two Bose Solo 5 Soundbars at Same Time AStreamNerds Audio, Video & TV 0 01-25-2018 01:25 PM
Electrical help can't run light and radio at same time Doolin Batteries, Univolts, Converters & Inverters 16 08-20-2017 09:04 AM
Same old, same old whitegs Tow Vehicles 36 08-11-2016 03:22 PM
How is this possible, same manf, almost same frame, diff GVWR carl2591 Tow Vehicles 7 07-15-2014 07:23 PM
