Old 09-10-2024, 08:14 PM   #1
2018 30' Classic
Dauphin , Manitoba
Exclamation Blank SUNEXPLORER Display Panel
I have a 2018 30’ Classic that has a SUNEXPLORER II display panel for the solar system. The display panel is completely dark and I cannot seem to reactivate. I have pilled the cat5 from the back of the panel for 30sec as described in other troubleshooting tips, but no joy, House batteries are charged but I have been connected to 120V shore power. Any help or suggestions would be appreciated.
BRN25611 is offline   Reply With Quote
Old 09-10-2024, 09:40 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
BRN25611, I suggest you give the good folks at Atkinson Electronics a call tomorrow. Here's their "contact page".
If you want to test the display, here's what I would do:
* Unscrew the head unit from the wall, disconnect the RJ45 cable.
* Locate the DC box in the curb side corner of the trailer and remove the cover. In it you'll find the Atkinson controller.
* Unplug the cable on the controller, and plug in a known good network cable and connect the other end to the display. If the display still doesn't work, it might have failed.
There are LED lights on the solar controller too. See if those light up.
I replaced my SunExplorer II unit display and controller from our 2019 Globetrotter with a Victron SmartSolar 100|30.
I'd be happy to give you my Atkinson parts if your troubleshooting determines the unit has failed, just send me a PM if so.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Atkinson MPT Solar Controller Sunexplorer Display - Virginia Shiny72 Airstream Classifieds 0 09-28-2021 04:01 PM
Sunexplorer II display dgeis2510 Electrical - Systems, Generators, Batteries & Solar 5 05-26-2020 02:20 PM
Sunexplorer display cycling dshan3 Generators & Solar Power 0 08-10-2018 12:45 PM
Help please - Sunexplorer display off? Anders79 Generators & Solar Power 1 07-18-2017 01:27 PM
