Old 05-31-2023, 11:52 AM   #1
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Battery Inverter as the main generator
Has anyone used an ECOFLOW Pro or alike with the 30A plug and used it as a primary generator instead of a gas generator? I like the appeal of putting up solar panels to have "infinite" energy.
My concern is running the AC. How long can it run even with the (2) battery expansion and the solar panels?
My other concern is weight. Carrying (2) Yamaha inverter generator and a (5) gallon jerry can is doable. However, carrying the inverter, (2) battery banks and a solar panel might become overwhelming in space and weight.
*Bonus question, do you guys know of any company that would rent ECOFLOW-type inverter to try on the field?
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 05-31-2023, 12:18 PM   #2
D & L Gates
Pella , Iowa
Your solar energy will only be as "infinite" as the sunlight you can receive. Clouds, atmospheric conditions, trees, angle to the sun -- lots of things could sub-optimize the recharging of the battery unit.
dee_gee is offline   Reply With Quote
Old 05-31-2023, 12:24 PM   #3
2016 16' Sport
Miami , Florida
And the amount of batteries to hold collected solar.
This really isn’t a generator. Why not just add some solar panels and lithium batteries to your camper? Thats all the solar generator is.
Shiny16 is offline   Reply With Quote
Old 05-31-2023, 12:40 PM   #4
Newberg , Oregon
Hoo boy. You’re going to get a lot of opinions on this. I love lithium power and I own a Tesla but these things are just marketing and in no way replace a gas generator.
The “Ecoflow Pro” is 3.2kwh which at 240v translates to 13 amp hours. That’s going to run an AC unit for a couple minutes. To get the advertised 25kwh you have to chain SIX of these things together. They’re $3500 each.
For camping needs, gas generator all the way. Most people learn pretty quickly that if they need AC they’re going to be a lot happier somewhere with a pedestal, so the generator is really just for topping off the batteries. Buy the Caravan to Carbon Neutral pack to offset, it’s actually a pretty cool partnership with National Forest Foundation.
starlite29 is offline   Reply With Quote
Old 05-31-2023, 01:11 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I hadn't seen this. Thanks for the tip.
2019 Ford Expedition Platinum
Old 05-31-2023, 01:41 PM   #6
2016 16' Sport
Miami , Florida
You could always get a Cyber Truck to hall the 6 units around. I’m not sure where you would put the solar panels.
Old 06-01-2023, 10:21 AM   #7
Glen Carter's Avatar
2018 19' Tommy Bahama
Downey , CA
I bought the Lion Safari ME at Costco to use to replace the generator. It's only 15A, but can run the microwave or my A/C for a little while...
You must turn off the converter when using these or a small generator because the converter will try to charge the batteries and overload generator.
Lion Safari ME Kit
Glen Carter is offline   Reply With Quote
Old 06-01-2023, 10:49 AM   #8
Stay CazuaL
cazual6's Avatar
Reseda , California
You misunderstood my question. I need it to run the AC. Having an inverter setup to run an AC is also taxing both on weight and $$.
I do have Li-On and Solar Panels on my rig.
WBCCI 9164
Old 06-01-2023, 11:14 AM   #9
1988 32' Excella
Robbinsville , New Jersey
For a stock 15k btu AC figure it will use about 2kwh each hour with the inverter not being 100% efficient. While not exact, that way it's easy to do the math 3.2kwh divide by 2 about 1.6 hours of AC with nothing else running. Then the hard part how long will it take to charge?
Old 06-01-2023, 10:31 PM   #10
Stay CazuaL
cazual6's Avatar
Reseda , California
That's what I figured. Thanks
Old 06-11-2023, 03:10 PM   #11
LADan
2019 25' Globetrotter
Monrovia , California
EcoFlow works great
I use the EcoFlow Delta Pro with my AS and it fits right on top of the battery box when camping. I also carry the dual champion 2500 generator to top off the Ecoflow during the day if solar could not top it off. The Ecoflow runs the A/C all night as the A/C turns on and off when the temperature is right on the inside of the AS. I am looking to install the Ecoflow Power Kit 5kwh when the price comes down.
LADan is offline   Reply With Quote
Old 06-11-2023, 04:19 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I carry one Honda 2000 and an empty 2 gallon gas can. Easy start installed. If we need the AC for day or so I stop and fill the can. The gen runs about 6 hours on the gallon in its tank which I keep full. Weight when traveling is about 55 lbs. I cannot imagine running the AC for a couple of days from an inverter and solar. So far solar power is neither cheap nor powerful for an RV. Generators pretty much are so.
F150 PowerBoost as Main Generator? SeaScott Electrical - Systems, Generators, Batteries & Solar 44 08-11-2023 10:52 AM
Main battery Tstidstfm General Motorhome Topics 1 12-20-2017 05:50 PM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Need Battery door and bottom vent door on main side Swimhard4 Airstream Classifieds 0 03-09-2015 09:27 AM
