Originally Posted by Skyhook
Recently our solar controller under bed started ticking, usually near sunup or sundown. I think it is confused whether to charge or not. It sounds like its sending morse code. When at Jackson Center the Tech said it is shot and needs to be replaced. He suggested Victron or something else.
Any suggestions? Why doesn't AS just install a battery monitor, a real battery disconnect and a solar system that does something?!
Hi
... since you asked:
Full battery disconnect: That shuts down the propane detector. They very much do *not* want to do that. Having an AS blow up due to their "faulty setup" likely would not be great PR.
Battery monitor: It's not something folks seem to ask for. They only realize that they need / want one after they have been boon docking a while. Indeed AS *does* put them on some RV's.
Solar that "does something": Not quite clear about this one. The stock solar on most AS RV's does indeed put current into the batteries. It's not a bad size for the stock batteries. Yes, that's to say that neither the batteries or the solar are sized for a week or four off grid.
Just for grins: Did all this stuff worry you *before* you bought the trailer? .... If it didn't then you probably would not have paid another couple thousand bucks to "fix it". Yes, they do indeed do studies on this price vs options stuff.
