The green is on the ground bar in the DC box
You’ll find the solar ground attached to the ground bar in the DC box. The yellow is connected to the Atkinson controller. It’s the large green wire in the lower left part of the DC box photo.
I swapped my Atkinson in our 2019 Globetrotter for a Victron 100/30 SmartSolar controller and put a disconnect in so I can do maintenance without having to climb on the roof and disconnect the panels.
I had installed a BMV-712 earlier but you can now get a SmartShunt without the display and just use the App.
BTW, my Victron does not have “Load” terminals - just PV and Battery
Good luck with your build!
-Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
