Old 09-11-2018, 03:17 PM   #41
Boxite's Avatar
2008 22' Safari
I want a simple, inverter type, MANUAL start GAS generator. I want gas because I consider it simpler, more powerful, and I don't mind carrying extra 5 gal in the back of the pickup, which has come in handy while boondocking several times. I don't want to deal with propane tanks, refilling, etc..
I also want MANUAL start because of WEIGHT, complexity, and battery issues. I only plan to start it occasionally and don't want to find the battery won't do it and I have to manually start it anyway. (I've already got several generators and know this problem first hand.) Champion has a model 100523 which is the same as that already discussed with these features. The problem is...no one stocks it. grrrr.
Old 09-11-2018, 09:03 PM   #42
ObviouslyKnot
james.mileur's Avatar
KAILUA , HI
Champion 3100-Watt RV Ready Portable Inverter Generator https://www.amazon.com/dp/B00BBDCE1S..._LciMBbP01YQ1W
Is this it?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-18-2018, 12:10 PM   #43
FCStreamer's Avatar
2014 30' Flying Cloud
That’s only 3100 watts.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 09-18-2018, 12:18 PM   #44
Mollysdad's Avatar
Originally Posted by james.mileur View Post
Is this it?
As I recall the 3500 was a special deal for Camping World.
It's actually the identical unit to the 3400 except for the decals. Champion claims the 3400 was underrated so they don't feel bad about the same genset being a 3400 and a 3500.
Old 09-18-2018, 12:18 PM   #45
ObviouslyKnot
KAILUA , HI
I've figured out my choke is manual, but an electric gas valve under the bowl is used as shutoff for LPG switch over and other protections, probably. Instead of a $70 replacement, I'm using the manual pull and jumper cable from nearby vehicle or trailer battery to get it running.
Yamaha 3500 watt inverter generator NEW Michael06 Airstream Classifieds 0 03-27-2014 08:17 PM
Do you own a Champion, Generac or Yamaha generator? robert@honda Commercial Listings 0 06-27-2013 11:32 AM
champion 3500 watt generator? bennyp Boondocking 7 09-25-2012 12:32 PM
Champion Inverter Generator moosetags Generators & Solar Power 1 10-27-2010 09:06 PM
