Old 08-09-2020, 03:43 PM   #1
2020 20' Bambi
Clayton , North Carolina
Any downside to Victron 100/30 use???
Say I buy a Victron 100/30 charge controller and install when I only have 180W of solar, but have intention of having 360W of solar (thus the 30 amps Victron). Then I decide not to go with the additional 180W solar and just buy small quiet inverter generator to top off batteries before nightfall. Is there any technical downside (not the fact I spent a little extra $$) to having the Victron 100/30 if I only have 180W of solar?
stephen
smsasf is offline   Reply With Quote
Old 08-09-2020, 04:23 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
it will work
that max amp is 30A.
waninae39 is offline   Reply With Quote
Old 08-09-2020, 04:24 PM   #3
2007 22' International CCD
No downside. The controller will happily work properly with the panels you have.
I have a similar MPPT controller thatís capable of much more, and it works just fine with only 150 watts worth of panel. Itís loafing, but it runs a bit cooler this way.
Old 08-09-2020, 04:55 PM   #4
Naples , Florida
Howdy!
There is no problem with using a Victron controller that is rated above your solar pane load. I do this quite often with no ill effects.
Have fun!
Old 08-09-2020, 05:00 PM   #5
And there is the final definitive answer from the acknowledged expert!
Nice to see you around, Lew! Hope you are doing well. Stay safe, brother!
Old 08-09-2020, 05:06 PM   #6
Naples , Florida
Hi Rich!
Doing well now! The first couple of months were quite a challenge, as I was in the hospital for 3 weeks with a variety of ailments (NOT COVID related though). Thanks for your concern.
I should be back on these Forums now for a while!!!!!!!!!!
lewster
Old 08-09-2020, 05:16 PM   #7
So glad to hear it! I managed to break the heck out of my right ankle in early March, but Iím back on my feet again and doing fairly well. Was lucky to find a very good Orthopedic trauma surgeon!
I still owe you a cup of coffee when we bump into each other somewhere. Let me know if you are in the Southern California region around Los Angeles area sometime!
Old 08-09-2020, 06:25 PM   #8
2020 20' Bambi
Thanks to all for the confirmation there will be no technical issues. Much appreciated. I can buy with confidence now.
stephen
Old 08-10-2020, 08:44 AM   #9
Naples , Florida
Will do!
lewster
Old 08-10-2020, 09:46 AM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Here's the math:
30A @ 14V = 420W
That's enough to reasonably handle 400W of panels You should be fine with anything that sized or less ( down to and including a 20W panel ...).
What happens if you go to 5 panels? Not a lot. If and when they get enough sun to give you more than 30A, you will be limited at the 30A point. Nothing catches fire. Nothing self destructs.
You *do* want the version with the built in Bluetooth ....
Old 08-10-2020, 10:12 AM   #11
Bacliff , TX
That Victron will last a lifetime. Get the bluetooth doogle and you can view the performance at anytime via your phone or iPad.
Couple of benefits is you can always increase your solar capacity. With solar efficiency technology advances, you may be able sometime in the next 5-10 years replace the panel you have with a higher capacity panel and the same footprint.
Also, this is MPPT lithium compatible. Should you upgrade to lithium batteries the next time your lead acid/AGM batteries die, you simply change the settings and you are good to go.
jimdelane is offline   Reply With Quote
Old 08-10-2020, 12:07 PM   #12
nevans's Avatar
1985 34' Excella
Victoria Harbour , Ontario
According to the Victron product information I saw, no dongle is required to access the 100/30 from Apple or Android phones.
nevans is offline   Reply With Quote
Old 08-10-2020, 01:06 PM   #13
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Correct. The latest versions have BlueTooth built-in.
thewarden is offline   Reply With Quote
Old 08-10-2020, 09:23 PM   #14
2020 20' Bambi
Victron MPPT 100/30 Purchased
... along with the battery temperature monitor and two cut-off switches.
Thanks again for all the advice. Need to get it installed, with help from my electrical/power controllers technical son, before I strike out for 30-60 days later this month. Stephen
Old 08-10-2020, 10:39 PM   #15
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
lewster, glad to hear you are back.
guskmg
Old 08-11-2020, 07:15 AM   #16
Bacliff , TX
I love these advances in modern technology. Soon all manufacturers will get on the bandwagon and have bluetooth apps. I still have the old lithium compatible Victron with dongle - before they integrated. Had it for a long time. Victron products are expensive and have a lot of bells and whistles that I never use. It is nice to have all those bells and whistles, even if I do not use them.
Old 08-11-2020, 07:20 AM   #17
Bacliff , TX
It is advised that you put a cut-off switch between your solar and your charge controller. I like the inline breakers. Easy to install and push button disconnect. If you disconnect the battery for any reason and the solar is on, you can burn out the charge controller.
eg: Marine Grade Inline 12V 50A Power Circuit Breaker manual reset
https://www.ebay.com/i/324193437060?...IaAqD-EALw_wcB
Old 08-11-2020, 07:41 AM   #18
Naples , Florida
guskmg
Thanks Gus!
lewster
Old 08-11-2020, 07:43 AM   #19
dznf0g's Avatar
Oswego , Illinois
A bit confused here. I have a marine cutoff switch AFTER the controller. The controller can be shut off via the app. Why would that damage the controller???
And welcome back, Lew!
-Rich-
Old 08-11-2020, 12:16 PM   #20
Naples , Florida
Thanks Rich,
On to the question; I place an appropriately sized circuit breaker BEFORE the solar controller and a 300 amp Blue Sea cut-off switch AFTER the solar controller. This allows you to isolate the controller if you have any problems that require either repair or replacement.
lewster
Victron 100/30 vs Victron 100/20? smsasf Generators & Solar Power 0 08-04-2020 06:09 PM
Victron 100/30 and Victron 712 installer needed in PA RMD Generators & Solar Power 0 07-01-2020 09:08 AM
Any downside to Ultrabreeze vent cover Gopher John Roof Vents, Skylights & Fans 10 11-05-2018 07:45 AM
Unable to reconnect to Victron 100/20 marter Generators & Solar Power 41 10-13-2018 05:35 PM
Any downside to getting a 2nd air conditioner? sakthorp Electrical - Systems, Generators, Batteries & Solar 53 07-23-2017 11:08 AM
