Air conditioning on house outlet?
I’ve got a 13500 BTU single dometic ac on my 2019 19 ft Flying Cloud. If I use a 10 gauge electric cord from an outdoors 15 amp 120 volt outlet, a dogbone 15 to 30 amp, then an EMS surge protector, then my 30 amp cord to the Airstream, can I safely run my AC if nothing else is on — no lights, no water heater, and no water pump and only gas setting on refrigerator? I’m moochdocking in a friends driveway at the beach in 90 degree weather with high humidity. Gets down to seventies at night but more concerned about humidity than temperature. Generator causes issues with neighbors. Am I correct that my EMS will prevent damage from low voltage by cutting off power if it fell too low? I have an Easy Start on the AC.
