Old 02-25-2019, 03:54 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Advice needed
I have factory installed solar on our 2012 FB FC that does not appear to be working. When I check the Sunexployer it shows my batteries fully charged, (we are connected to shore power) however the solar charge amps show 0 and the solar Amp hours at 4.6 even though it has been sunny the last few days.
I have never had this issue before and know little to nothing about solar. So any advice on where to begin trouble shooting is greatly appreciated.
urnmor is offline   Reply With Quote
Old 02-25-2019, 04:25 PM   #2
Registered User
2016 25' Flying Cloud
Fairfield , California
With the batteries fully charged there would be no place for the solar panels to send the juice. Try turning on the fans and the lights that should have something show up coming from the panels. If nothing then run the batteries down about 25% and don't have any other source of power coming in to the batteries.
Matti
Mattirs is offline   Reply With Quote
Old 02-25-2019, 05:14 PM   #3
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Matti
Good advice. You’ll need to unplug from shore power and run the battery down a bit before the solar controller would wake up.
daleyocum is offline   Reply With Quote
Old 02-25-2019, 08:39 PM   #4
urnmor's Avatar
Berlin , Maryland
First let me say thanks for your advice. Please bear with me as I don’t really understand, however if I give it a shot. You are telling me that my batteries have to be run down about 20 to 25 percent for solar to kick in and register amps. Am I correct?These are new batteries (just installed before we left on our trip)
Old 02-25-2019, 09:11 PM   #5
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Apparently this true. The Atkinson solar controllers allow the batteries to discharge too much before initiating a charge. However, in my case, the controller was hit and miss and worked when if felt like it.
At the suggestion of others here, I upgraded to the Victron 75/15 blue tooth controller (you can get a lower or higher rated controller to fit your solar needs).
Now the solar tries to keep the batteries in float to keep them topped up.
Edit: You will loose your Sunexplorer display when you upgrade, but get much more information and programability via the Victron blue tooth. I re-purposed the Cat5 cable to power a USB outlet in the old display location. But you could always use the old Cat 5 for a voltage display instead.
rowiebowie is offline   Reply With Quote
Old 02-25-2019, 09:23 PM   #6
Sag Harbor , New York
When connected to shore power, the standard AS OEM battery monitor does not show the correct battery voltage IMO. It instead shows the voltage output of the converter/charger [typically about 13.7]. Maybe your setup is different?
Disconnect from shore power, wait a couple of hours, then check your battery voltage.
Peter
Old 02-25-2019, 10:32 PM   #7
rowiebowie's Avatar
2012 Avenue Coach
Peter
Excellent advice. When I upgraded to the Victron MPPT controller, I can now see real time battery voltage as well as solar charging.
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
Computer / Accessories Purchase Advice Needed hex Forum Admin, News and Member Account Info 16 11-20-2003 11:54 PM
Advice needed: hitch, controller, etc. Stu Clark Hitches, Couplers & Balls 8 02-23-2003 01:05 PM
30 Footer Advice Needed JaceBeck Our Community 13 10-04-2002 11:51 AM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
