Old 01-11-2020, 09:31 PM   #1
2005 19' International CCD
Jamestown , North Carolina
A 50 & 100 watt solar panel wired in parallel ok
The 100 watt panel 12v - renogy eclipse vmp - 17.7v & 5.7 amps
The 50 watt panel 12v - renogy vmp - 18.3v & 2.9 amps
I'll be using an mppt controller, Before I purchase these items, I want to make sure this set up will work. IN parallel this will add the amps to 8.6 amps and run with the lower voltage of 17.7?
Burns is offline   Reply With Quote
Old 01-11-2020, 10:55 PM   #2
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
NO
the panels must match in parallel
in series OK
waninae39 is online now   Reply With Quote
Old 01-11-2020, 11:20 PM   #3
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
For series connection – the same current rating of the panels is more important.
For parallel connection – the same voltage rating of the panels is more important.
Source: https://solarpanelsvenue.com/mixing-solar-panels/
I think Burns calculations are correct and would configure the panels in parallel resulting in 8.6A at 17.7V totaling 152W. A parallel connection of these mixed panels only loses 1.2% of the potential wattage.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
solar panel: series or parallel waninae39 Generators & Solar Power 5 05-20-2022 06:30 AM
100 watt solar with deep cycle flooded batteries? Jfarthing Generators & Solar Power 4 06-14-2019 08:53 PM
Bluetooth 2,300-Watt Gasoline Powered Digital Inverter Generator with Parallel Combo Kyacker Generators & Solar Power 2 02-04-2019 08:15 PM
Suggestions on Upgrading stock coach batteries to 400 Watt from stock 160 Watt odonnell71 Sprinter and B-van Forum 5 05-07-2017 07:59 AM
When was the 50 watt solar panel upgraded to 100 W busb2 Sprinter and B-van Forum 43 07-25-2016 04:11 AM
