Old 03-20-2023, 11:53 AM   #1
2022 16' Caravel
sanford , Florida
2022 16' Caravel solar
There is a decent MPPT charge controller installed for the 90W panel on the roof, and there is an input near the batteries for an external.
I was surprised to see that input is wired directly to the batteries bypassing the MPPT controller altogether.
There are extra ports on the roof, can external panels be plugged in there?
Why would Airtstream bypass the charge controller???
Thanks for any suggestion.
bustedrudder is offline   Reply With Quote
Old 03-20-2023, 02:51 PM   #2
2023 28' International
Mercer County , New Jersey
It is separate for a few reasons:
- If the panels are mismatched (Volts or amps - depending on a parallel vs series configuration), you will get degraded performance.
- Most portable panels come with a controller built in.
- Who'd want to climb on the roof every time to connect/disconnect the panel?
jeffb831 is offline   Reply With Quote
Old 03-20-2023, 03:47 PM   #3
2022 16' Caravel
sanford , Florida
Thanks!
The panel we had with our last trailer does not have a charge controller, I'd installed that inside the camper. Looks like they install the same cheap one I had on "portable" panels now so I can modify the one I have or get a newer lighter folding one.
Now I see the error in my logic.
I appreciate the education
caravel
2022 Caravel 20FB with solar package and 12v fridge question aarstream Boondocking 14 10-12-2022 09:22 PM
2022 GT 27 FB Twin inverter upgrade. Do 2022 trailers have a fridge roof vent? foobar Batteries, Univolts, Converters & Inverters 9 05-13-2022 09:38 PM
One week out from order completion on my 2022 20FB Caravel aarstream 2020 And Newer Caravel 5 10-02-2021 08:37 AM
2021 versus 2022 Caravel order donnabray 2020 And Newer Caravel 10 04-27-2021 12:25 PM
