Old 05-07-2020, 04:13 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
14.3 Absorption / Float Charge?
I found an old Morning Star SunSaver 10 controller that I had forgotten I had. As an experiment I attached a 100w solar panel into the SunSaver- and then into the trailer batteries. Just prior to that I had my batteries plugged into a BatteryMINDer and the batteries were fully charged and reading 13.2 thereabouts. I unplugged the BatterMinder and then plugged in the Solar/Morning Star. The battery monitor inside the trailer then read 14.3. Is that right? If the batteries were fully charged or on absorption, shouldn’t they be around 13.2 as per the BatteryMINDer?
tjwoods1 is offline   Reply With Quote
Old 05-07-2020, 05:49 PM   #2
2018 25' International
Slidell , Louisiana
Well the SunSaver has a float charge of 13.7 not 13.2 and Bulk Charge of 14.1 or 14.4 depending on the selected battery type. Depending on the firmware, it could default to bulk mode for a bit when first turned on, I can't tell you about that. It's also possible it is confused or faulty.
Brian
BayouBiker is online now   Reply With Quote
Old 05-07-2020, 05:55 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
From the manual, page 33:
"Depending on battery history, the battery remains in the
absorption stage for 3 or 4 hours before transitioning to the
float stage."
Also, the battery will slowly coast down from Absorption voltage to Float voltage over a period of several hours.
There is also a section on multiple chargers which I didn't read.
Al
Investigation: absorption refrigerator fires waninae39 Refrigerators 0 07-11-2019 09:00 AM
Absorption vs Float AgBullet Electrical - Systems, Generators, Batteries & Solar 2 05-31-2019 04:36 PM
Any charger around with a high voltage absorption phase? tvoneicken Batteries, Univolts, Converters & Inverters 6 12-13-2017 07:17 PM
Electric heating element for Norcold Absorption Refrigerator Carol in Air Refrigerators 3 08-21-2014 07:39 AM
New atwood gas/absorption fridge lewster Commercial Listings 17 02-25-2012 07:59 AM
