Old 02-11-2023, 01:33 PM   #1
1978 31' Sovereign
Richmond hill , Georgia
Wiring LED pod lights
Hello all. I am currently renovating a 1978 sovereign. I am in the process of designing and installing electrical components, as the rig had no OEM wiring remaining when I bought it.
I have a question regarding recessed LED dome lights. I would like to have a row on each side of the center line of the ceiling about once every 4 feet, each side with its own switch so I could control which side is on.
My question is, if I wished to have a switch operating a string of 6 lights, are these lights typically wired in series to the switch? In other words, would the correct route be as follows:
power source -- distribution panel -- switch -- light -- light -- light..... --- ground?
These are the lights I will be going with.
https://www.recpro.com/3-2-recessed-...0k-warm-white/
Thanks!
Brandon2022 is offline   Reply With Quote
Old 02-11-2023, 02:10 PM   #2
1978 31' Sovereign
update...
I found this instructional. Thanks for reading!
https://shop.explorist.life/shop/all...it-wiring-kit/
Old 02-12-2023, 09:40 AM   #3
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
If your lights are listed as 12volt DC, they should not be wired in series. Bring the positive wire through the switch, and branch it to all the lights. the lights are all individually connected to Ground.
if you wire the lights in series, they will get dimmer as you add more until they stop working.
in certain cases like christmas lights, they use the lights in series to drop the voltage to each individual bulb, but in the case of a fixture rated for 12 volts, all of that happens internal to the individual light fixture.
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
Can of beans is offline   Reply With Quote
Replace Incandescent Marker Lights with LED Marker Lights Fwrandall55 Lights - Interior & Exterior 1 08-11-2021 08:34 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
