Old 12-18-2024, 09:52 PM   #1
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
While Parked ,Running Lights Option
Wanted to share this idea.
At times traveling while overnight at a campsite or an event some Airstream owners like to have their running lights illuminated at night. There are many posts on the use of a Fuse between the disconnected trailer 7 pin cord. The fuse is jumped between the battery 12 volt 7 pin hot terminal and the running lights terminal.
I used the fuse method for years until recently on a trip it would not work? Confused at first I tested then remembered the trailer 7 pin cord battery hot terminal was dead. With the DC-DC upgrade and Lithium it was used for other applications and not a feed back to the truck.
So back home bored with the trailer in storage I bought off Amazon a MECMO 7 pin Truck side plug. I never liked the loose fuse method I wanted a more secure dust and water resistant connection while parked.
It works perfectly just used the running lights harness wire and fused it to a battery terminal clamp that can be placed on the positive post in the battery box. Later I may use a weather proof switch or not-
Disadvantage it some parts cost and your labor. Also the we can do it better advise to follow.
Advantage I now have a way to at least have running lights till I get repaired if the truck connector fails to power the trailer cord. I also can activate any other pin to test lights or brakes
Name:	7 pin 1.jpg
ID:	449622   Click image for larger version
Name:	7 pin 2.jpg
Life is a Highway is offline   Reply With Quote
Old 12-19-2024, 10:17 AM   #2
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
Looks fancy and has other utility than running/rally lights.
I put in a remote switch which connects to the running lights near the DC box. It's detailed here. I really like the remote, it makes it easy to turn them on and off or flash the lights when I lose my trailer in a parking lot.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 12-19-2024, 12:15 PM   #3
NutmegsCamper's Avatar
2023 23' Flying Cloud
Another , World
Wait a minute... You've lost your trailer in a parking lot?
NutmegsCamper is offline   Reply With Quote
Old 12-19-2024, 12:53 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Happened to me! Parked next to another silver one….
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 12-19-2024, 01:51 PM   #5
Another , World
Wowzer! That's one big field full of Airstreams!
Old 12-19-2024, 04:37 PM   #6
jeffmc306's Avatar
McHenry , Illinois
Alumalina 2023! Unfortunately the Tom Johnson Camping World site was wiped out by the flooding this fall. It was our first time attending and a wonderful event.
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 12-25-2024, 11:16 AM   #7
Bessie's Avatar
2023 28' Pottery Barn
John’s Island , South Carolina
Turn on Your Camper Lights RV Lights with LITESWICH 2.0 Camping Accessories https://www.amazon.com/dp/B075JP5C8C. I stink at this but I bought this on Amazon, super easy & fun! Hopefully the link will work?
Bessie is offline   Reply With Quote
Old 12-25-2024, 01:38 PM   #8
Silver Grasshopper
2021 22' Caravel
Pensacola , Florida
Running light while parked
Hello,
First time posting recently bought a 2021 caravel 22FB we came across the Liteswitch for lighting while parked.work reallywell.
https://www.ebay.com/str/liteswich
Grey monkey is offline   Reply With Quote
Old 12-26-2024, 01:31 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by Grey monkey View Post
Hello,
I'm pretty sure that wont work for OP. His DC to DC prevents power from going back out to the 7-pin which would be required for that to function, would work for a stock system though(except for the Trade Wind).
Old 12-26-2024, 02:13 PM   #10
JeffKim's Avatar
2021 16' Bambi
Yes, DC-DC was my motivation as well with the remote. Regardless, I find the remote much more convenient than having to plug into the 7-pin.
I'm a little surprised there's a patent for this device; it seems pretty basic - a plug with a switch, but then what do I know? I'm also wondering if it's fused. I'd guess the lights are fused somewhere, but I'd feel better with the fuse jumper.
2017 Audi Q7 3.0T
WBCCI 6343
Old 12-27-2024, 06:51 PM   #11
Airstream - Other
Airstream - Other
Lady Lake , Florida
Correct
Correct the 7 pin is dead for the DC-DC I’m grabbing power fused off a remote battery box power post it is 7 amp fused the 7 pin is ground side switched through a Bosch Relay.
No running lights, brake lights or trailer lights work from tow vehicle RichHog 1969 - 1973 Safari 42 05-02-2019 08:42 PM
New 2014 Sport 16' - why are the running lights blinking when parked? OurJuneBug Airstream Trailer Forums 3 02-08-2019 11:10 AM
Tire Care while parked winter storage wimpy Classic Motorhomes 2 03-13-2018 02:38 PM
Ventilation while parked/not in use GinaNBob General Motorhome Topics 27 06-24-2016 09:07 PM
Charging with the Truck while parked?? DJW Electrical - Systems, Generators, Batteries & Solar 30 07-19-2015 07:27 PM
