Old 12-13-2024, 10:04 AM   #1
Ky
2020 27' Globetrotter
Davidsonville , Maryland
Where to splice into tail light wiring
Hi all! I am looking for a way to wire in a 4 pin tail light connection into my 2020 27’ GT FBT at the back bumper.
Situation: I have a Fiamma bike rack mounted on the trailer. With two bikes on the rack, the tail lights are partially blocked (but still acceptable). I want to put a cover on the bikes for bad weather, which will block the tail lights.
I welcome all suggestions. One idea I have is to wire in a 4 pin connector at the back, install one of those “tail light bars” you see under truck tailgates, on the AS bumper, below the rack. …but I’ll need a connection to plug it into.
As such, where can I access the tail light wiring at the back of the trailer? I have a 4 pin connector on my truck I could use, but I really don’t want to run a wiring harness all the way under the trailer.
Thanks All!
kylentz is offline   Reply With Quote
Where to splice into rear clearance lights TreeWalker Lights - Interior & Exterior 2 04-21-2024 08:37 PM
Tail light repair turned into a disaster pickupjason Lights - Interior & Exterior 3 06-05-2020 05:48 PM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 12:34 PM
Longer Battery Cables - Replace or Splice? RDM16CCD Batteries, Univolts, Converters & Inverters 3 02-26-2007 11:01 PM
Electric wire splice on magnets LI Pets Brakes & Brake Controllers 15 09-03-2006 12:45 AM
