Old 09-24-2019, 12:08 PM   #1
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
What is the size of AWG exterior lights
Calling for electrical help .
What is the size of shrink butt connector do I need for rewiring the exterior lights?
I am changing out 1/2 of my exterior lights ( cheap damn things ) as they blink or most of diodes are not lighting up due to water damage
Thank you
Laurence
LAWBC is offline   Reply With Quote
Old 09-24-2019, 02:43 PM   #2
1966 22' Safari
Fredericksburg , Texas
Laurence, we used 16ga marine grade stranded for the exterior lights. The shrink butt connector packets normally have a wire range they can be used for, say 16ga-18ga. Good luck.
Bubba L is online now   Reply With Quote
Old 09-29-2019, 11:58 PM   #3
LAWBC's Avatar
Arrow Clearance lights other than
Nice mod Bubba L on your clearance lights, bet those won't leak .
http://www.airforums.com/forums/f73/...a-55-fc-whale-
reno-154849-10.html
The more I see and read about the crappy led clearance lights on our trailers the more I am looking at alternative lights like these ;
https://www.grote.com/products/47912...molded-bullet/
or
https://www.etrailer.com/Trailer-Lig...DG52440VP.html
Airstream Ink ,, take note your crappy lights do not last Cheap Cheap!
Laurence
Old 09-30-2019, 06:50 AM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Here’s my blog post on the same project including ways to help seal them from water
http://www.airforums.com/forums/blog...lacement-3015/
The article I wrote for DoItYourselfRV.com should publish this week also, but the post post should cover all you need.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 10-01-2019, 10:09 AM   #5
LAWBC's Avatar
Clearance lights
So I did read your blog on this and thank you for that. I installed one light with silicone and one without, when lit-up both had condensation in them.
Now to be honest my lights like yours my are from another source LED supplier so maybe they are coming out of the factory not sealed properly.
I am thinking because I have read and seen Auto guys modify their lights and take them apart then reseal the whole fixture, and maybe that is what is needed to be done here .??
Laurence
What are the two sets of 6 AWG connection to the battery? tbaugh Batteries, Univolts, Converters & Inverters 15 08-10-2019 02:07 PM
Splicing 12 AWG to 14 AWG question - help nocmanus Electrical - Systems, Generators, Batteries & Solar 34 02-21-2017 06:30 PM
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 11:05 AM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 10:27 PM
Wire AWG (gauge) needed for full restoration. briheath Electrical - Systems, Generators, Batteries & Solar 6 06-07-2009 10:14 AM
