Old 05-26-2021, 03:09 PM   #1
2004 25' International CCD
2012 25' International
2019 27' Tommy Bahama
slaton , Texas
weak left blinker
Any advise is greatly appreciated!!
not sure where to start checking for a solution for my problem with a weak left blinker.
just bought a 2019 T. Bahama 27'. in checking out the lighting we noticed the left blinker was about 4 times weaker than the right.
had no problem with lights on our 2012 International.
TV is a 2015 Chevy Silverado 2500 series. truck blinkers have same intensity. So, i'm assuming the problem is on the trailer side
is this a problem with the 7 pin connector? its getting voltage as i do have a blink on the left . brake lights are fine. Electronic cleaner for the 7 pin? Or is this a bigger issue?
thanks for your help!
gnowlin is offline   Reply With Quote
Old 05-26-2021, 04:13 PM   #2
Leilanisteve's Avatar
2015 19' International
Boise , Idaho
You might need one of these:
https://www.etrailer.com/Wiring/Tow-Ready/20142.html
I had some strange blinker issues on my 2016 Chevy and 2015 trailer and this solved it. I tried to copy a thread link on this topic but wasn’t able.
This corrects some issues with LED lights as far as I recall.
Steve
Leilanisteve is offline   Reply With Quote
Old 05-26-2021, 04:34 PM   #3
2019 27' Globetrotter
Missouri Valley , Iowa
Steve may be right. I'd also check the bulb connection / socket. Clean the contacts. And maybe loosen and then snug up the mounting screws of the light assembly itself. This sounds like possibly a ground problem.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-26-2021, 08:36 PM   #4
1955 26' Cruiser/Overlander
harrisburg , Missouri
I agree with Dan, I would start by checking your ground.
Aaron
a duncan is offline   Reply With Quote
Old 05-26-2021, 10:26 PM   #5
batman's Avatar
1964 22' Safari
modesto , California
^^ X3. I agree with Dan and Aaron. One week turn indicator sounds suspiciously like a ground issue. The bulb contacts and socket may be oxidized and need to be cleaned and burnished.
-Dennis
batman is offline   Reply With Quote
Old 05-27-2021, 08:31 AM   #6
slaton , Texas
Steve
Thanks!! that will get me started.
gregg
Old 05-27-2021, 08:34 AM   #7
slaton , Texas
Dan
Tks Dan
I will try to clean, just didnt know i could access the blubs. will also try Steve's
suggestion
gregg
Old 05-27-2021, 08:35 AM   #8
slaton , Texas
Aaron
thanks Aaron!
Old 05-27-2021, 08:39 AM   #9
slaton , Texas
-Dennis
Tks Dennis
it well may have an oxidation issue as its been sitting in NJ for the past 2 years about 5 mi from the ocean. will try and clean
gregg
Old 07-14-2021, 03:55 PM   #10
slaton , Texas
solved weak left blinker
Just FYI for those that might have the same problem with a weak blinker issue. I did finally solve the issue (that only a small array[4 out of 20] of LED's did dimly blink).
in checking the fuse box the originally fuse I looked at looked OK, it looked fine, but I had my Chevy fuse guide turned incorrectly so i was looking at the wrong fuse.
i did located the correct fuse and it also looked ok but the link was burned partially thru but still had enough metal to partially power the circuit.
I installed a new fuse and all is fine, full bright and all 20 LED's light up and blink.
thanks to all for the help!!
Old 07-14-2021, 05:20 PM   #11
Images: 59
I had this same problem with my Tradewind. Just needed to top up the blinker fluid.
Right Blinker gone dark Sbb Lights - Interior & Exterior 0 07-10-2015 06:24 PM
Keep blowing fuse for brake/blinker lights bweldon Lights - Interior & Exterior 2 07-09-2015 03:19 PM
Left turn and left brake lights not working Morgan guy Lights - Interior & Exterior 9 02-01-2015 07:08 AM
Should this be a blinker light? MonaxLisa Lights - Interior & Exterior 4 02-16-2011 07:42 PM
Blinker problems towing a jeep 1987_345 Classic Motorhomes 3 08-27-2009 08:00 AM
