Old 01-24-2017, 09:55 AM   #21
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
^^ Those are way brighter than mine, I set mine up to fire crossways, not straight down, to get a more subdued even glow. You are using a strip of lights, not a block of three about 1" 1/2 long? I can't take a pix, the glow too low to catch without a tripod or overkill flash.
Where I'm at now, the street light across from me washes out the glow, hardly visible.
"Chip Tank" is in Redcrest Ca.
CDONA is offline   Reply With Quote
Old 01-24-2017, 10:28 AM   #22
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Two sets of led strips, 48 and 36. I just stuck them on to see how it would look. May try tilting, not sure. With this set, however I can change the brightness.
The Colonel is offline   Reply With Quote
Old 01-25-2017, 05:40 PM   #23
Florence , Alabama
Installed lights underneath AS today, a lot of work. Routed cabling and brought the four cables in thru the forward right storage compartment, but inside the fake wall. Tomorrow I'll install an outlet there and provide power to system.
Old 01-26-2017, 04:41 PM   #24
Florence , Alabama
Finished power install today. Ran 12V wiring from CB panel using empty slot to inside forward right storage compartment. I mounted a switch and an indicator led light to false wall and stowed control box and wiring behind wall.
The Colonel and Southern Belle
Old 02-25-2017, 05:51 PM   #25
billymyers56's Avatar
2020 30' Classic
Commerce , Texas
ID:	280467Click image for larger version
Installed today.
billymyers56 is offline   Reply With Quote
Old 02-25-2017, 06:00 PM   #26
Florence , Alabama
Nice job
Old 02-25-2017, 06:16 PM   #27
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
mmmmmmmm........ I think I just found my next project.
billymyers56 - where did you source your lights? Looks like you can change colors on them, which is appealing.
wulfraat is offline   Reply With Quote
Old 02-25-2017, 06:28 PM   #28
2020 30' Classic
Commerce , Texas
https://www.superbrightleds.com
Old 02-25-2017, 08:21 PM   #29
Mike1997's Avatar
1998 36' Land Yacht Widebody
Reidsville , Georgia
Images: 14
These are impressive lights. However, I chose to do it the cheap easy way. Got two 20' stands of rope lights from Big Lot on sale after Christmas. Once set up in a campsite for more than a few nights I put them along the wheel base and around the patio. Both are hooked to a photo light sensor so they operate automatically. They seem to hold up well in rain and water in South Florida rain storms. Cost was about $30 for everything. Simply role it up when I am ready to leave.
Not only does it provide indirect lights, but its very easy to find at night. The reflection on the lower storage bays and chrome wheels gives it an effect of floating....or at least that's what my neighbors say
Mike1997 is offline   Reply With Quote
Old 02-27-2017, 09:33 AM   #30
wulfraat's Avatar
Originally Posted by billymyers56 View Post
Thanks. Did you go for the dual 20' runs?
Also - did you simply stick the lights to the underside of the belly pan?
Old 02-27-2017, 08:24 PM   #31
2020 30' Classic
Commerce , Texas
There are three 16' stings of lights. Yes they are stuck to the belly pan.
Old 01-07-2021, 10:21 PM   #32
Clovis , California
LED lights - under belly
Did you just use the factory tape?
nhaas is offline   Reply With Quote
Old 01-09-2021, 09:15 AM   #33
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
Attached are photos of the Boogey lights I had installed last summer. You can have these put on your rock guards as well. It has an app as well as a small remote. Many colors (purple, white, green red, blue) and you can leave them on steady, or have them run through all kinds of programmed displays.
Just don't leave them on at night!
ID:	386559   Click image for larger version
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 01-09-2021, 09:16 AM   #34
jamieb1086's Avatar
Also, these lights were installed with tape. No drilling.
Jamie
Old 01-12-2021, 03:50 PM   #35
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Hi Jamie ! Boogey lights look like the way to go if your willing to spend the extra coin.
It looks like pretty even light without the hot spots. Yours came out great !
I got in touch with a guy named Brian Butler @ Boogey.
Very helpful guy. Their customer service alone has me leaning in their direction. There are many options to consider !
Did you purchase one or more of their "kits" to put yours all together ?
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 01-13-2021, 07:46 AM   #36
jamieb1086's Avatar
I think my installer ordered a basic kit and then necessary extensions to finish the job. Iím very happy with it!
Jamie
Old 01-13-2021, 07:54 AM   #37
B4WEDI's Avatar
2006 19' Safari SE
Thanks !
T & K
Review - CCD Dinette Cushions by Accent Upholstery Stephen Mick Upholstery, Blinds, Walls & Interior Finishes 20 06-04-2020 08:12 AM
Interior Accent Lights Frank&Mike General Interior Topics 32 11-26-2014 06:37 AM
Clearcoat?! lifting on Accent strips.... SilverToy Clearcoat, Exterior Paint & Trim 3 10-18-2005 08:05 PM
Blue Accent lines boltos Clearcoat, Exterior Paint & Trim 2 03-24-2004 10:41 AM
