04-03-2019, 04:02 PM
Turn signal activates brakes
Also depressing the TV foot brake pedal locks up the yrailer brakes. Any ideas?
Also, my trailer is a 1973 Argosy. Do I stand a chance using the old turn signal wires, to pull new wires, or are the old wires come from the factory tied to something that would prohibit pulling them through.
The wires go from the umbilical chord throuch the chassis.
04-03-2019, 04:33 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
I remember reading the older AS wiring color code does not match current vehicles and must be checked at the connector to verify what wire does what before connecting to a vehicle.
Garry
04-03-2019, 04:54 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
YEP...went thru similar with our 63 Safari, test light TV connecter wires, note function.
Power each AS connector wire and note function.
Match TV to AS.
Repair/replace parts as needed.
Draw yourself,(and next owner)🤔, a diagram.👍
04-03-2019, 05:03 PM
Wiring for plugs are correct, as they worked fine since 2011 when I got the TV
Anyone else jeard of this problem
04-03-2019, 05:18 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Do you have a brake controller in the TV? If so it is probably adjusted too strong for the braking. Back the power knob on the controller down to the minimum and try it again After you correct the connector wiring mistakes. Or the brakes are grabbing and need servicing. Grease on the linings will do that, The plug is wired wrong if the turn signals are going to the brakes. I know on my 87 trailer I had to remove a 9 pin plug and install a 7 pin and I think the color codes might not have matched. I do not think you have any chance of just pulling new wires to the signal lights. Never had these exact problems. But have dealt with a lot of trailer, TV wiring issues over the years.
04-03-2019, 05:56 PM
Sag Harbor
, New York
More information would help IMO. What tow vehicle, for instance, and is your brake controller OEM or after-market?
Is anything new about your rig? You have been posting here for a while, and it seems likely that this is a new problem IMO. What equipment etc. is new? Have you done any wiring work in the trailer recently?
Good luck,
Peter
04-03-2019, 08:12 PM
Tampa
The clue that both the brake and turn signal activate the brakes, makes me suspect a short. Check the trailer plug and make sure it's not gunked up. Follow up with a simple test light or a volt meter and start tracing wires.
04-03-2019, 08:16 PM
1987 25' Sovereign
Fort Collins
Proves that electrons are not to be trusted ...
Alumacoot
“We are confronted with insurmountable opportunities.”
04-03-2019, 08:27 PM
1971 21' Globetrotter
glen carbon
you have a ground problem
04-03-2019, 08:34 PM
Its a Prodigy 1 brake controller
As I said everything worked fine....out of the blue it started acting up..I suspect mice
I might have to pull the belly off to rewire it.
04-03-2019, 09:21 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
It is probably something simple, not complicated. More trouble shooting needed with a simple test lamp.
Dan
04-03-2019, 10:00 PM
1997 25' Safari
Montgomery
, Alabama
Check the whole length of the umbilical cord...it may be a cut in the cord causing a short...ask me how I know
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
04-03-2019, 11:03 PM
Salem
, Oregon
Hi, start simple first. I have found and fixed vehicles where the tail light bulb was bad. On a double filament bulb, one filament can break on one end and make contact with the other filament. This will make thing work weird. I also had a vehicle of my own where when I had a new hitch welded onto it, the welder melted two wires together. It was at night when I discovered it. I put my foot on the brake pedal and my dash lights lit up.
[both cases are a form of feedback]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
04-04-2019, 11:28 AM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
Silver flash is correct. Don’t over think This. Clean the bulb socket on the tail light make sure that the bulb shell is still a good ground. The turn signal is back feeding to the controller. It has happened to me with my 75 Argosy MH cruse control. Simple things first.
04-04-2019, 11:56 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
If you have a chevy and the cruise control is also involved, it likely is a relay. Problem occurs whether or not you are connected to the trailer.
Google the symptoms and you’ll find it is not uncommon and readily fixed.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
04-04-2019, 12:55 PM
2022 25' Flying Cloud
NCR
, Ontario
If you have a brake controller , it is probably adjusted too strong for the braking. adjust it so that its just locking the AS and then dial it down a bit
or
give Andy at CANAM a call. He is an EXCELLENT asset on how to dial it in.
he did ours and it now rocks 100%
04-05-2019, 08:13 AM
Classy Roscoe
One simple check is to look inside the umbilical cord plug. Back off the strain relief screw. Carefully back out the tiny screw that holds the hood of the 7 way plug in the plug housing and push out the plug internals to expose the wiring. Examine the wires that nothing is shorted.
If it is, repair, pull the cord back into the hood and try to find that little screw that retains the plug inside the hood and secure. Tighten the strain relied back down and travel on.
Safe travels.
04-10-2019, 08:10 PM
1973 25' Tradewind
Geneva
You won't be able to access all the 12 volt wiring by going into the belly pan. It's above the floor. Check where your wiring comes into the trailer. It's possible something has come loose or touching other wires. Once it comes into the trailer it all goes different directions. Wiring standards are different from current so do not go by color. You need to go by functionality.
