Old 11-17-2023, 10:38 AM   #1
JandB's Avatar
2024 27' International
Noblesville , Indiana
Tail lights flicker
Our 2024 27FB tail lights flicker just a bit when the 7 way is connected to our truck. When I unplug, it stops. When I turn on the lights or hit the brake, the lights work as they should.
It doesn't matter if the power switch just inside the door is on or off, and it doesn't matter if I'm hooked up to shore power or not.
The truck lights do not flicker; just the trailer.
Any ideas?
JandB is offline   Reply With Quote
Old 11-17-2023, 10:45 AM   #2
1966 22' Safari
Fredericksburg , Texas
I had a similar issue last year. You may want to use something like CorrosionX on the trailer to truck 7 way plugs. It worked for me. Good luck
Bubba L is offline   Reply With Quote
Old 11-17-2023, 11:27 AM   #3
JandB's Avatar
Is that like a dielectric grease or contact improvement product?
Jeff & Barb
Old 11-17-2023, 11:32 AM   #4
JandB's Avatar
I see the product now.
Both truck and trailer are brand new so I doubt I have any corrosion, but certainly worth a look.
Old 11-17-2023, 12:30 PM   #5
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
Lots of times when the tail lights come on by themselves it is an indication of a bad ground. Ck your ground connections because something is looking for a ground and using the tail lights for one. I know this sounds weird but you can trust me on this one.
JEWare
John Ware is offline   Reply With Quote
Old 11-17-2023, 01:59 PM   #6
JandB's Avatar
Speaking of bad grounds...
When I moved my unmounted solar charge controller to set the dial to AGM (from the factory lithium setting), the yellow wire fell out. I fixed that and when I moved it back, I noticed a lot of copper showing on a mid sized (2-4 ga?) ground wire at the buss bar. When I moved that wire slightly, it fell out!
I reinstalled both and properly tighted ALL the connections.
I mentioned it to the dealer, and the tech said he's not surprised and sees it all the time.
Pretty sad for a hand built, proud to say we're the best, Airstream.
Old 11-17-2023, 04:26 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
Sounds like a ground problem
CRH is offline   Reply With Quote
Lights flicker when using macerating toilet mrhankuk Electrical - Systems, Generators, Batteries & Solar 3 12-19-2022 09:03 PM
Lights flicker when water pump runs Climber Electrical - Systems, Generators, Batteries & Solar 6 10-25-2017 08:57 AM
Ceiling lights flicker, tail lights are dim Zeitlupe 2011 - 2015 International 11 07-01-2016 07:29 AM
Lights flicker kathy149 General Interior Topics 3 01-31-2014 01:47 PM
Lights dim and flicker tinman9 Lights - Interior & Exterior 1 11-18-2013 08:40 PM
