Old 05-20-2025, 02:50 PM   #1
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Tail Light Wiring Location
Can anyone please tell me where the wiring for the tail lights is routed in a ‘70’s trailer?
I’ve heard it is in the ceiling but would like to do corn before I start disassembling things.
Pictures would be great.
There is an intermittent short in my running lights on my ‘77 Safari,
I’ll start by checking the umbilical cord connection at the front but I’m concerned it is a chafed wire inside a wall.
AldeanFan is offline   Reply With Quote
Old 05-20-2025, 03:26 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
My 71 was run down the ceiling, street side I think. I ran the replacement in the same place.
Old 05-20-2025, 06:13 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 199
RE: Intermittent Short, Running Lights, '77 Safari
Greetings AldeanFan!
Before jumping into a major project, I might suggest examining both ends of the umbilical cord as well as the connector in the wall of your Safari as well as the connector on your tow vehicle for corrosion and tight connections. On both my '64 Airstream and '78 Airstream, two-thirds of my problems with running lights were directly connected to corrosion either on the wiring connections behind the connector on the tow vehicle, the blades on the RV type 7-pole connector, or corrosion on either the end or the wire connections on the trailer side. The vast majority of my problems disappeared after 2003 when I dispensed with RV blade type connectors and went to the 7-round pin connectors very similar to what Airstream utilized well into the 1970s. These are the 7-pole connectors utilized on semi trucks, and as such have excellent moisture shields over the wiring at the back, and the round-pins are an interference fit meaning that they self-clean as they are inserted/removed. I suspect that you may find that corrosion on/in one or both of your two female 7-pole connectors and/or one or both of your male 7-pole connectors may be the source of your errant short.
Good Luck with your Investigation!
Kevin
This is an example of the male connector that I am using on both of my trailers:
This is the female connector that I am using on my tow car:
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 05-21-2025, 05:17 AM   #4
AldeanFan's Avatar
1977 23' Safari
Thanks for confirming,
That is a big help
Old 05-21-2025, 05:20 AM   #5
AldeanFan's Avatar
1977 23' Safari
Thanks for the suggestion,
I’ll definitely check the 7pin connectors.
I’m confident this so not a problem at the truck end because I have two trailers and two trucks. The issue persists with both trucks but only the one trailer.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
Old 06-07-2025, 08:39 AM   #6
Dan@LED4RV's Avatar
Denton , North Carolina
left tail light
Sometimes they are run down the center in the ceiling and sometimes on the left side. Always behind the the left turn/tail is where they all run together. Behind the left side you will find the right turn signal wire. This is just for the Stop, Tail, and Turn.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Tail light wiring location 1967 Overlander GenesDream Lights - Interior & Exterior 3 06-13-2021 04:23 PM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 11:34 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Tail Light Wiring sshadow Electrical - Systems, Generators, Batteries & Solar 4 10-31-2003 10:17 AM
