Old 09-08-2024, 07:17 PM   #1
2002 19' Bambi
Ellicott City , Maryland
Stop/turn lights and TV fuse rating issue
Hello:
We have a 2002 Safari that uses p/n 2057 bulbs for the stop/turn lights. They are also used for the marker lights. On a recent camping trip, we found our Safari stop and turn lights were not working as we were about to depart the campsite. The lights were working fine when we left home. The failure must have happened on our trip to the campsite. We tracked the problem down to a blown fuse in our TV secondary fuse box. Our TV uses a 7.5 Amp ATM fuse for the stop/turn lights. We replaced the fuse which solved the issue and headed home.
I looked up 2057 bulb specifications and found stop light wattage is 27 Watts which translates to 2.1 Amps at 12.8 Volts. Our Safari has four stop lights so that’s 8.4 Amps. I measured 7.9 Amps (close agreement) with the engine running and stop lights on. When the two turn signal filaments are also on, I expect additional current. I thought about switching to LED bulbs but don't want to install load equalizers at this time.
I believe the fuse isn't blowing all the time since it's a slow blow. Perhaps the fuse degrades over time. I am curious if other TV's have a higher rated fuse (greater than 7.5 Amps) for trailer stop/turn signals? Thank you.
Graceric is offline   Reply With Quote
Old 09-14-2024, 04:45 PM   #2
JandB's Avatar
2024 27' International
Noblesville , Indiana
My truck has a 10 amp fuse for the right and left (separate 10 amp fuses).
Trailer Stop/Turn Right - 10A
Trailer Stop/Turn Left - 10A
JandB is offline   Reply With Quote
Old 09-14-2024, 08:48 PM   #3
1988 32' Excella
Robbinsville , New Jersey
You could put in 1 LED on each side.
Wazbro is online now   Reply With Quote
Old 09-14-2024, 09:04 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Did you clean the bulb fixture/ socket?
With the proper LED enclosure there is usually enough of them to give the proper “load”. They are much brighter and run cooler… great “upgrade”. They use the existing “socket” to connect.. which still requires maintenance.
Once contacts are cleaned, use some dielectric grease or other protection to minimize corrosion.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-15-2024, 10:57 PM   #5
2002 19' Bambi
Thanks for the replies. I did clean all of the light fixtures. I ended up changing the TV fuse size to 10 Amps. This is not too much of a change so I believe it is okay. So far, the problem is solved.
How to connect stop lights and turn signals on a 2017 Toyota Hilux? lalo1893 Lights - Interior & Exterior 2 06-14-2024 09:14 PM
LED Upgrade stop, turn and tail lights -- 3 dandedar Airstream Classifieds 0 08-21-2015 09:23 AM
Replacement Stop/Turn/Tail Lights for 2005 Bambi (19') Phoenix Lights - Interior & Exterior 3 02-28-2015 12:29 PM
Disconnect running lights from stop/turn at rear can? MexicoMagico Lights - Interior & Exterior 3 04-14-2014 10:32 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 03:01 PM
