Old 03-16-2020, 01:26 PM   #1
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Stair light repair
My Airstream is a 2012 with the LED light above the door, generally pointing down. When we bought the trailer, it worked, then it became intermittent. I could not remove the plastic lens so I bought a replacement LED and removed the entire aluminum cover. I replaced the LED and recaulked the cover.
That worked for a while then it became intermittent and I gave up...for some time.
This past week I figured out how to remove the plastic lens without breaking it. One must slip a knife blade under the lower side and push up, after removing the two screws. I could wiggle the bracket and get it to work so my diagnosis was a bad ground. It appeared that the rivet attaching the LED holder was really never clamped hard enough to make good contact with the case. So, I used a small file to clean up both surfaces, squeezed in some dielectric grease, and used a C-clamp to really squash the rivet and bracket to a tight clamp.
Presto! Now it works properly. A simple rivet that was not properly installed. If it fails again, I will use a bolt and nut.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-16-2020, 03:09 PM   #2
2018 25' International
Slidell , Louisiana
Brilliant!
Old 03-16-2020, 03:31 PM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Thanks for the tip Larry!
The light on our 2019 GT has behaved the same way since new. If you rap on the housing the light comes on. Now I know what to look for.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is online now   Reply With Quote
Stair broke...saved rivet gogonow Insurance & Claims 1 01-13-2016 08:17 PM
1968 Sovereign restoration / Missing Stair Catch tmwsiy 1965-1969 Sovereign 0 08-22-2013 09:16 AM
1965 Globetrotter stair repair help needed dzuroski 1965 - 1969 Globetrotter 0 12-04-2012 11:44 AM
stair and awning questions Hardenburgh General Repair Forum 3 04-17-2012 08:40 AM
Dry rot on the flooring above the stair ckeysor 1984 - 1989 Sovereign 6 09-26-2006 05:15 PM
