Old 09-14-2024, 11:02 AM   #1
2022 27' International
Longboat Key , FL
Sewer push button light
How do u disconnect sewer push button light. Have replaced once. Stuck in on position. 2022 27ft International
Timandcin11 is offline   Reply With Quote
Old 09-14-2024, 01:05 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Greetings Tim and Cin! We are glad to have you with us on AirForums.
I have a 2013 trailer, and I have the opposite problem: my light no longer works. I never used it anyway, so I have not tried to fix it.
I know your problem has been discussed on AirForums before; multiple people have reported it on late model trailers. I don't know if there is any easy fix, but someone will probably come along soon with better information.
Good luck and I hope you are enjoying your 27 footer.
SSquared is offline   Reply With Quote
Old 09-14-2024, 01:36 PM   #3
2015 30' Classic
2023 25' International
Houston , Texas
Same problem with us. We have been waiting since May (4 months now) for the light to burn out. Airstream spared no expense on that little light bulb but cut corners on the switch.
veratipton is offline   Reply With Quote
Old 09-14-2024, 02:01 PM   #4
19’ Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
Why not just remove the bulb?
2017 Bambi 19 Flying Cloud
BikeCamper is offline   Reply With Quote
Old 09-14-2024, 03:49 PM   #5
2015 30' Classic
Houston , Texas
Great idea but I’m now obsessed with finding out how long the bulb will burn 24/7.
Old 09-14-2024, 05:07 PM   #6
JandB's Avatar
2024 27' International
Noblesville , Indiana
If it's like ours, (a push on/off LED) you can pull the light out and cut the ground wire. There should be 4 wires going to the light; keep pulling until you see 2 just wires. Cut the ground wire. I would put a short U bend in both cut ends and hook them on to each other and tape over them. That way you can shove the wires back in and secure your light in place, and would be able to get to that cut ground wire if AS ever comes up with a better light that won't come on at random.
I'm second guessing which one is the ground as I don't have my trailer here. I replaced my light with an LED light and separate switch and I'm fairly certain the white/black is backwards from the rest of the trailer which has white ground wires, but... I've slept since then.
Anyway, easy enough to test with a voltmeter or test light.
JandB is offline   Reply With Quote
Old 09-14-2024, 08:50 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Until you can “fix” it… Pull the bulb
Replace the switch yourself…. It’s not that hard…
If you cut wires, cut individually leaving as much wire as possible!!! Do not allow them to touch. Then secure individually with an insulated connector on each the tape properly. This will keep them protected minimizing the chance of a “short” you may never be able to resolve…. Among other more significant issues.
The next caretaker will appreciate these steps…
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-14-2024, 09:40 PM   #8
JandB's Avatar
There is no bulb to pull on these push button LED lights.
If you cut the ground wire, there is nothing to short but to ground.
I didn't suggest removing any wire. All the length will be there if you just cut and secure together until needed later.
Old 09-22-2024, 01:03 PM   #9
Fayetteville , Arizona
My dealer replaced the magic F&@ing light at no cost. It still turns on randomly somehow. I’ve never used the light on any trailer because I own several flashlights.LoL
I finally had my dealer disconnect it. Also no cost
Andy Karakos
Fayetteville, NC
akarakos is offline   Reply With Quote
Moen Single faucet push on push off LuckylLil12 Plumbing - Systems & Fixtures 4 03-08-2023 12:48 AM
Push button for light near black water drain m4dball Lights - Interior & Exterior 5 07-23-2017 01:37 PM
Push button pantry latch gloran General Motorhome Topics 2 09-03-2015 10:00 PM
Push button deadbolt lock jendon Doors & Locks 0 03-09-2010 06:14 PM
