Old 01-04-2020, 06:52 PM   #1
Spreadhead's Avatar
2007 25' Safari FB SE
Houston , Texas
Safari bathroom light not working
Hello,
One of the lights in the bathroom of my '07 25' Safari stopped working.
It is a World Friendship Co. RV Luminaire model no. 1WF0404002.
I thought the bulbs simply burned out, so I replaced them and it still does not work. I searched the forums, and searched for a replacement light online without luck.
Does anyone have an idea for either a replacement or other solution?
Thanks in advance,
ID:	358652   Click image for larger version
Spreadhead is offline   Reply With Quote
Old 01-04-2020, 07:00 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Before writing off the fixture have you checked if there is power to the fixture? Have you checked the circuit breakers?
Old 01-04-2020, 07:03 PM   #3
Spreadhead's Avatar
Houston , Texas
Great question. I have checked the breakers and everything seems to be functional. I did not specifically check power to that particular light. Thank you, I'll try that.
Old 01-05-2020, 09:50 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My 02 Safari SS has a switch behind the bathroom faucets that controls power to the light fixture in the sink area and the shower. It is near the water heater switch. Maybe yours has something similar.
Richard
Old 01-05-2020, 10:14 AM   #5
Spreadhead's Avatar
Houston , Texas
Thanks, Richard, I will look for that switch. It is amazing to me that there are still things to be discovered years later.
Old 01-05-2020, 10:17 AM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The switch broke on the same fixture in our 06 19' Safari SE a couple years back.
If you do end up replacing the fixture you might consider this LED fixture, purchased at Camping World. We liked it so much we also replaced the same fixture over the sink and over the dinette. The switch is a toggle, so you can turn on or both sides on.
Name:	Bath Light_Sm.jpg
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 01-05-2020, 10:36 AM   #7
1976 31' Excella 500
Chappell Hill , Texas
Those lights are a simple design. It may be a loose wire connection as well. Just take it off the wall and make sure the wire connections haven’t worked loose. A 12V test light costs less than $10 or so and will tell you if you have power to the wires after the light fixture is removed. Google for videos too. If you have power to the wires then just buy another light.
tbashin is offline   Reply With Quote
Old 01-05-2020, 10:37 AM   #8
Rich W's Avatar
I'm In , Kentucky
Our 2006 has the switch for that light on the same panel as the plugs, under the vanity, just past the faucet. It's very easy to miss. I have to constantly remind the wife.
We had our AS at Jackson Center for repairs. When we went to check on it our technician said "your bathroom light is out". I reached down and flipped the switch, light came on and he said ..."oh".
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 01-26-2022, 11:53 AM   #9
SandKSmith's Avatar
Phoenix , Arizona
I've got a couple of these World Friendship 1WF0404002 lamps where the switch has failed. Has anyone found a replacement where the screw holes match? I'd like to reuse the screw holes rather than drill new and someday run into this same problem again.
thanks,
Steve
SandKSmith is offline   Reply With Quote
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 12:25 PM
bathroom fan and two lights not working terricrowe26 Lights - Interior & Exterior 0 05-29-2018 08:14 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Bathroom lights not working BCMC27 Lights - Interior & Exterior 5 06-29-2013 09:10 PM
help, 12v center light not working. garthbf Electrical - Systems, Generators, Batteries & Solar 4 08-15-2006 06:36 PM
