Old 10-31-2021, 02:07 PM   #1
2003 25' Safari
North Augusta , South Carolina
Running lights on trailer blow truck fuse at 35 mph
My 2003 Safari running lights, when hooked up as per factory specs, when speed hits about 35 mph. I have installed a cheap set of running lights (Walmart specials) and they work fine. I have disconnected each of the running lights at the light, checked for a ground - found none. Cannot get the back taillight assys off to check them due to Airstream design - they attach from the inside of the skin.
I have changed out the umbilical thinking that may be the problem. No.
Any suggestions.
Barry Myers is offline   Reply With Quote
Old 10-31-2021, 02:27 PM   #2
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Sounds like an intermittent short in the wiring that only occurs when road vibration is present. There is nothing on those circuits that should be affected be trailer speed.
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Running Lights truck fuse keeps blowing Pongo Lights - Interior & Exterior 12 10-09-2021 06:15 AM
No running lights, brake lights or trailer lights work from tow vehicle RichHog 1969 - 1973 Safari 42 05-02-2019 08:42 PM
Fast Blow or Slow Blow Fuses? SilverWind Batteries, Univolts, Converters & Inverters 0 09-14-2018 03:23 PM
Replacing running light-did I blow a fuse? Knudsvig Lights - Interior & Exterior 4 01-31-2016 02:18 PM
Fuse Continues to Blow in Tow Vehicle tmeagle1 Lights - Interior & Exterior 6 07-01-2008 06:23 PM
