Old 01-03-2021, 01:28 PM   #1
2018 30' Flying Cloud
New Hudson , Michigan
Rock Lights on a trailer....
So have been looking at rock lights for my TV, but then was thinking, why not on the trailer? Was considering this because we tend to do long hauls that put us coming into campgrounds late at night. Wondering why they couldn't be hooked up to your back-up light signal coming from the trailer connector to a relay, so that they automatically came on anytime you were backing in?
Anyone out there done anything like this? Not sure if there is an easy place to tap the backup line on the trailer wiring on a 30FC Bunk model...
Thought about just putting them on a separate switch, but they'd probably be illegal in most states to have on going down the road, and figure the most time I'd use them would be when backing up. Figured I could also wire a connector to the trailer batteries to plug it into if I ever wanted them on when the trailer was not connected (like some do with their running lights). TIA!
ekbruster is offline   Reply With Quote
Old 01-03-2021, 07:26 PM   #2
2007 22' International CCD
I have a nice set of marine stainless steel docking lights for a boat that I will be installing on my Airstream as backup lights. Probably in the banana wraps up front to illuminate a wide swath.
Plan is to use a relay activated by the backup signal in the 7-way connector on the Airstream and use 12volt power from the house batteries. Still working out exact location and wiring access.
I think it’s doable.
rmkrum is online now   Reply With Quote
Old 01-03-2021, 09:09 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Just wondering...
Are we sure there isn't a yellow back-up wire in the AS harness?
I know they stopped using them but are we sure the wire is no longer in the 7way.
In the auto world the harness can be pretty generic and the wiring may be there but the option not, ie... the heated mirrors.
“I’ve always thought that over planning was just a firewall against not being sure of what you really want to do.”
RLC
Tahawus
Old 01-03-2021, 09:11 PM   #4
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
Forgive my ignorance, but what’s a “rock light”? I’ve never heard that term. Is it like a spot light that’s used to illuminate the space behind the trailer when backing? Or is it something else?
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is online now   Reply With Quote
Old 01-03-2021, 11:48 PM   #5
It’s also known as a ‘ditch light’ on locomotives. Basically a very low mounted light to illuminate obstacles. My Tacoma has a set of driving lights that I refer to as ditch lights, because they really light up the shoulder of a road.
Old 01-03-2021, 11:53 PM   #6
Dennis C's Avatar
Got it, thanks. Sounds useful if you can work out how to mount and power it.
Dennis
Old 01-04-2021, 08:05 AM   #7
Bob,
I believe the line is available in the 7-way harness still, because it is standard, but have to figure out where to best tap-into it to get the signal from the vehicle.
Old 01-04-2021, 08:17 AM   #8
Ours is right in the TV plug...👍
Along with LEDs in the fixture we be good.
ID:	386223   Click image for larger version
RLC
Tahawus
Old 01-04-2021, 08:24 AM   #9
richw46's Avatar
Lexington , Kentucky
On my Toyota the center pin is the backup wire, just like Bob's. I don't have backup lights on my AS but my boat trailer's surge brake requires it so you don't engage it when backing up. I would think this is a pretty standard wiring thing.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
No running lights, brake lights or trailer lights work from tow vehicle RichHog 1969 - 1973 Safari 42 05-02-2019 07:42 PM
Trailer lights brakes marker lights not working bwaysteve General Repair Forum 1 04-30-2018 07:31 PM
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 03:00 PM
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 10:05 AM
West Western "ROCK"docking while Boondoocking: Rock Hunting Ray Eklund Boondocking 1 04-03-2015 03:43 PM
