Old 08-21-2018, 03:20 PM   #1
Danny Bell's Avatar
1966 28' Ambassador
Colville , Washington
Pollack plug on 1969 sovereign
Hi guys,
Does anyone have a Pollack 7 pin schematic for a 69 Sovereign.
The Pollack male plugs in right behind the propane tanks and then goes to my truck receptacle. My truck receptacle is modern wiring, the trailer is original, so I know I'm going to have to reconfigure the Pollack male plug.
By the way, I'm replacing the original Pollack plug with a Phillips which is identicle to the original Pollack plug, because that is what our local Napa sells.
Thank you,
Dan
Danny Bell is offline   Reply With Quote
Old 08-21-2018, 07:57 PM   #2
ALí UM- MONEY's Avatar
1976 31' Sovereign
Ball Ground , Georgia
1969 plug
When I changed out both the cable and plug on our 1969 Sovereign I found It time consuming. Frount of one plug back of another etc. If no one has an easy method you may do what I had too. Use a multimeter on the back side of the male plug installed in yourAS to locate the neutral or ground. Then I used my battery charger to power each pin finding lights.charging line brakes. Then match the TV sources to each.It took me more time then it should.
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
ALí UM- MONEY is offline   Reply With Quote
sovereign
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
