Old 05-24-2022, 12:29 PM   #1
1971 27' Overlander
Findlay , Ohio
No right turn signal
The left turn signal and tail light work fine. The right tail light works fine. The right turn signal does not work. It is not the bulb, as I have check three different light bulbs and checked them in the left rear light and they work fine. I checked using a volt meter and there is ~ 12V going through the tail light post (as expected). I used the volt meter on the turn signal post and it alternates between 0-1 and 10-12 volts as it blinks (as it is supposed to).
Any insight or help or ideas are greatly appreciated!
~Brian
bwhitaker is offline   Reply With Quote
Old 05-24-2022, 02:45 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I'd recommend only turning left.
2019 Ford Expedition Platinum
Old 05-24-2022, 03:46 PM   #3
Rich Jenkins's Avatar
2022 23' Globetrotter
Venice , Florida
I had a mis-functioning right rear turn signal assembly that failed on my 2017 30FC. I ordered a replacement assembly and installed it in the parking lot of a Casino in Washington State, while we were on the road, if I recall correctly.
Unfortunately it was not a simple plug and play; I had to solder on the wires and seal with electrical tape.
ďCharacter is doing the right thing when nobodyís looking. There are too many people who think that the only thing thatís right is to get by, and the only thing thatís wrong is to get caught.Ē - J.C. Watts Jr.
Rich Jenkins is offline   Reply With Quote
28' CCD: Right turn signal blows fuse michaero 2002 - 2005 International 5 11-14-2021 05:17 AM
2016 flying cloud right Farrar brake light and turn signal out. Anyone replaced this ras.robshort 2016 - Current Flying Cloud 4 05-16-2016 07:04 PM
1973 Overlander right turn signal Lothlorian Lights - Interior & Exterior 3 04-06-2012 10:14 AM
NEWB, Right turn signal and brakes come on?!? steven2themax Brakes & Brake Controllers 11 08-10-2010 12:01 AM
Rear right side turn signal not working s4misfaction Argosy Motorhomes 4 05-27-2010 03:39 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
