Old 10-26-2017, 08:43 AM   #1
OvrlndrinAR's Avatar
Fayetteville , Arkansas
New umbilical setup
Hey guys. I need a little help with my remodel. I'm replacing all the wiring. I'm having trouble figuring out how to set up the new umbilical connection. I've removed the old 7 pin connection from the trailer...what do I replace it with? I haven't had any luck finding a 7 blade connector to put in that spot. Thanks in advance for the help!
OvrlndrinAR is offline   Reply With Quote
Old 10-26-2017, 08:46 AM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Are you looking for the whole cable, like this?
https://www.amazon.com/Conntek-Black...7+pin+rv+cable
You can get it in different lengths, and they also have junction boxes available.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 10-26-2017, 08:47 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Lots of people eliminate that plug connection altogether and just hard wire their umbilical in, and "pot" it using silicone or Vulkem.
I chose to go with a set-up very similar to the original plug-in connection. I had no trouble finding the parts I needed. I blieve I found what I needed at Northern Tool.
good luck!
Old 10-26-2017, 10:17 AM   #4
Thanks for the quick reply. So hardwiring in the umbilical is an option but I like the clean look of a plug there. Could I use this:
https://m.northerntool.com/products/...7924?adv=false
And then have a cord with a connection on both sides? Thanks again for the much needed guidance.
Old 10-26-2017, 10:25 AM   #5
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
I got my plug and cord from VTS. Went with the all weather blue one. Not so much because of the more flexible wire but the color was nice.
Dingo Girl is offline   Reply With Quote
Old 10-26-2017, 10:43 AM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I moved to the round seven pin connectors like heavy trucks use, both on the trailer end and the tow vehicle end.
New 7 way cable (umbilical cord) rbs Electrical - Systems, Generators, Batteries & Solar 7 05-22-2013 11:01 AM
New Umbilical Cord for 2004 Classic Go_Navy Electrical - Systems, Generators, Batteries & Solar 9 02-19-2013 04:57 PM
new umbilical cord crispyboy Electrical - Systems, Generators, Batteries & Solar 6 06-09-2010 07:59 PM
New 7-Pin trailer umbilical wiring soldiermedic Electrical - Systems, Generators, Batteries & Solar 3 03-16-2009 11:26 AM
Install new umbilical cord beginner5 Electrical - Systems, Generators, Batteries & Solar 7 07-09-2007 09:02 PM
