Old 08-23-2018, 01:04 PM   #1
1966 22' Safari
Cedar Rapids , Iowa
New main panel
Adding an outlet for new gas/electric water heater so need to replace 2 space original panel(one space being used for 30A main, other space has double 20A breaker). Kind of confused as to Main, sub panel etc. Thinking this one would do the trick allowing me to setup the 30 amp main in one space and a couple of double 20A breakers which would allow me the additional circuit plus an empty space for another circuit or two for future. Would this panel do the trick as I believe it would? Thanks all! Greg
https://www.ebay.com/itm/Ge-Main-Lug...IAAOSwatRbWell
mysilverbullet is offline   Reply With Quote
Old 08-23-2018, 04:12 PM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
That panel is huge! 125 Amps is really overboard for a TT.
I would recommend this one:
https://www.progressivedyn.com/rv/ac...0-amp-240-vac/
vintagemotor is offline   Reply With Quote
Old 08-23-2018, 04:48 PM   #3
1966 22' Safari
Cedar Rapids , Iowa
Im looking to do inexpensively as already have the GE breakers including a 30a that I would use as main and would only have to purchase one additional breaker and box is much cheaper than PD5500, like only $25, is small, (8x10) to fit in existing location. Would this panel work? Thanks!
33' Main Panel Light & Floor Sensor Lights gbstats Electrical - Systems, Generators, Batteries & Solar 0 07-18-2017 10:14 AM
Polishing a new panel to match an Alclad panel 66replica Cleaning, Stripping & Polishing 4 09-13-2014 12:29 PM
Main Panel Box Replacement TouringDan Electrical - Systems, Generators, Batteries & Solar 2 04-05-2013 02:14 PM
1983 310 coach wiring diagram for main panel scotdo Classic Motorhomes 7 03-08-2009 07:12 AM
main control panel bison Electrical - Systems, Generators, Batteries & Solar 4 05-24-2004 09:19 PM
