Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 03-28-2012, 04:27 PM   #1
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
New LED teardrop Clearance Light Removal
A source of corrosion has been under the exterior clearance lights on many trailers. My new ones are LED fixtures with no visible means to remove them.
How can the lens be removed to get under them to inspect and treat for corrosion?
doug k
Old 03-28-2012, 05:45 PM   #2
Retired.
. , At Large
doug k
The lenses clip on the frames, which are then unscrewed from the trailer. Some also have double sided sticky tape holding them on.
Old 03-28-2012, 09:27 PM   #3
dkottum's Avatar
I can't wiggle them loose. Where are the clips?
doug
Old 08-04-2020, 04:03 PM   #4
2019 19' Tommy Bahama
Albuquerque , New Mexico
There are two small square clips that connect the lens to the metal frame that is fasten to the trailer skin. You have to pry starting at the small end and work to the large end of the lens to pop the clips from the frame.
Dtjeep is offline   Reply With Quote
Old 01-31-2021, 07:02 AM   #5
Roadroamin's Avatar
2011 27 FB International
Athens , Ontario
So lets say we removed the lights, all of them. Where can I get the new ones with the rubber gasket that protects the rig against further corrosion?
Are the lights that the dealers are selling the ones?
Appreciate any feed back
Roadroamin is offline   Reply With Quote
Old 01-31-2021, 07:29 AM   #6
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Amazon sells them. I replaced all my old clearance lights with these. https://www.amazon.com/s?k=airstream...ss_ts-a-p_1_15
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
New Air conditioner advice? marzboy Furnaces, Heaters, Fireplaces & Air Conditioning 92 07-26-2012 10:41 AM
Mid way through interior vinyl removal - how to remove remnants and cross-hatch? mikeandnora Upholstery, Blinds, Walls & Interior Finishes 24 07-12-2012 09:12 PM
Third brake light livexl Classic Motorhomes 5 05-31-2012 07:28 AM
corrosion ? around light fixture? Lily&Me General Interior Topics 20 04-04-2012 11:26 AM
Stolen in Seattle Area - Brand New 31 foot Airstream! Airstreamnw Our Community 47 03-28-2012 05:35 PM
