Old 08-14-2018, 05:18 PM   #1
1966 22' Safari
Cedar Rapids , Iowa
Need electrical advice
Hello,
I have a '66 Safari which has the small 115v panel. Someone added a window a/c unit in rear window so I assume they put a 30A main disconnect on the left and a stacked dbl 20A breaker on the right side. I'm guessing there was 2 single 20A breakers originally? Anyhow, one breaker powers the AC and curbside power, the other appears to power the streetside outlets and refrigerator. I'm replacing gas only water heater with a 110v/gas unit and need to access power. Everything's in the wall, so cannot access anything. Shy of double tapping one of the breakers(which I'm not even sure I could, it's so tight), or running a wire from the refrigerator outlet back seems like only options. Anyone else have any experience here or ideas? Thanks so much! Greg
mysilverbullet is offline   Reply With Quote
Old 08-14-2018, 05:51 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would replace the panel. Install a 3rd breaker for the water heater.
Can you route the new wire beneath the cabinets? In an area where it won't be damaged?
Old 08-14-2018, 07:08 PM   #3
1966 22' Safari
Cedar Rapids , Iowa
Checked for 30A panels, and appears they all have 2 breaker lugs. Should I be looking for a 60A panel with 4 or more, since it's going to have a 30A main, it'll only be 30A, correct? Thanks so much for your help!
Old 08-14-2018, 07:45 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Yes.
The main breaker should be 30amp. Even if you go with a larger panel.
Check the type of breaker you currently have. You can use them in the New panel if that panel uses the same type. You will only be out the cost of one breaker and the panel.
NEED ADVICE! Buying a 2015 vs. 2016 -- what do I need to look for??? lovespirit Buyer Guidelines 26 07-31-2015 03:17 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Need advice with electrical upgrade/renovation MDSilverado Electrical - Systems, Generators, Batteries & Solar 11 01-14-2010 06:46 PM
Need electrical system expert advice boondockdad Electrical - Systems, Generators, Batteries & Solar 25 11-16-2008 05:03 PM
Electrical advice needed nilesrob Electrical - Systems, Generators, Batteries & Solar 17 04-17-2007 06:06 AM
