03-12-2021, 05:58 AM
1972 31' Sovereign
Tucson
, AZ
Name for front exterior lights
What is the name of the front exterior lights on a trailer? they seem to be for visibility, maybe courtesy lights? Does anybody know where i can find a diagram of the lights on a 72 Sovereign? I’m guessing generic Airstream or generic trailers have similar lighting names - looking to replace with leds but need to know what brightness to use.
03-12-2021, 09:02 AM
1964 22' Safari
modesto
It sounds like you are asking about the "Scare Light". To replace that bulb. Remove the cover, extract the bulb, Go online and look up something like SuperBrightLEDs . com and cross reference yours to a new LED replacement.
https://www.superbrightleds.com/cat/...0aAk7iEALw_wcB
Here is a related thread with some more info: https://www.airforums.com/forums/f44...nt-162719.html
As far a brightness, I would get the brightest LED they offer. It being LED should not melt your lens cover if it is plastic because LED's do not produce a lot of heat. I replaced my scare light and used a Signal-Stat 3600 with a clear lens. It uses a 1157 dual element type bulb and Low/High switches.
Sorry, no help on a wiring diagram for your particular unit. Someone else may chime in with that.
Hope that helps.
-Dennis
03-12-2021, 10:31 AM
1972 31' Sovereign
Tucson
, AZ
Hope that helps.
-Dennis
i probably should have included a photo - i think i know what you mean by the scare light, which seems to be by the door. i would call these running lights of some sort but “running lights” may just refer to the rear lights so my searches were pretty fruitless. i need covers as well.
03-12-2021, 10:55 AM
1967 26' Overlander
Bugtussle
, Oklahoma
Vintage Trailer Supply calls them clearance marker lights https://vintagetrailersupply.com/ext...marker-lights/
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
03-12-2021, 11:09 AM
1972 31' Sovereign
Tucson
, AZ
Originally Posted by mikextr
ah, thanks, seems like they may be marked “cluster lights” in some places - maybe because they are in a cluster? and that marker lights above the windows were yellow and below were red. Does that make sense?
03-12-2021, 11:15 AM
I'm In
, Kentucky
I used to work for a trucking company, we called them marker lights. Amber are in the front and red are in the back, lights or reflectors. It's the law in most states, probably all of them. I've never seen any other colors in many years of driving.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
03-12-2021, 12:22 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
VTS carries several different LED versions of vintage Airstream Marker Lights...although, it looks like they are out of the amber ones right now.
Shari
03-13-2021, 09:35 AM
1976 31' Excella 500
Chappell Hill
Clearance lights.
03-13-2021, 03:43 PM
1986 25' Sovereign
Huntsville
, Alabama
I've bought clearance lights at Wally world and Harbor Freight that match the old ones on my 86.
03-13-2021, 05:10 PM
2018 27' Globetrotter
Elbert
, CO
In the Globetrotter parts manual, ours are called "LED clearance light, Amber".
03-13-2021, 11:19 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
For light fixtures that are hard to find. Take one off and go to NAPA if they don't have one in stock it can probably be ordered.
guskmg
03-14-2021, 08:40 AM
1972 31' Sovereign
Silverton
, Oregon
Those should be listed as double bullseye marker lights, in Amber for the front.
I replaced mine with cheap ones from Amazon, and they didn't last long enough to put the interior in, I ended up replacing them all again.
because of the style of that light, there isn't a sealed shut version, the lens is always replaceable. In the version I found the LED board was potted into the base so all the led are stabilized on the board and sealed, the lens is just a superficial cover. because I also had my interior out, I ran real grounds to the lights instead of them being grounded to the shell also.
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
