Old 05-15-2025, 12:06 AM   #1
2018 19' Flying Cloud
Eugene , Oregon
Mysterious Red Light on Roof.
While returning from a late night walk with the dog, I noticed a red light glowing on the top of my new 20' 2025. It is just in front of the AC and looks like it is on the domed TV antenna. I checked the inside antenna activation button and it is OFF. Any ideas what this is ... and if it has any parasitic drain when the trailer is in storage?
tjwoods1 is offline   Reply With Quote
Old 05-15-2025, 05:31 AM   #2
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
on ours, its the tv antennae as is has a power amp inside
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,3x MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 05-15-2025, 05:55 AM   #3
2024 30' Flying Cloud
Oak Park , Illinois
Yes, it is the power antenna. Noticed that on mine too. In the area where the TV is or media player connection, there is a small round button that will turn the antenna on and off which will also turn that outside light on and off too.
sfranklin is offline   Reply With Quote
Old 05-15-2025, 07:24 AM   #4
3OnOurWay's Avatar
2021 Interstate 24GL
Confirms antenna is powered.
Should have a draw of just under 1 amp
3OnOurWay is offline   Reply With Quote
Old 05-15-2025, 08:04 AM   #5
Eugene , Oregon
I turned off the TV antenna button, but the light is still on.
Old 05-15-2025, 08:35 AM   #6
3OnOurWay's Avatar
You got us on that one if light still on
Since you mentioned, it is brand new 2025, I would not be surprised if there’s something just slightly wired incorrectly. I get sense It’s part of the first year or two of RV ownership and use
Likely time to have dealer track it down, the other thing you could do is track it down yourself self diagnose, and then learn more about all the different systems.
Old 05-15-2025, 08:56 AM   #7
2025 25' Trade Wind
Beaver Dam , Wisconsin
I have a 2025 Trade Wind. It also has a red pilot light on the outside TV antennae.
The switch to turn it "OFF" is close to the radio/entertainment center. It is a tiny little button on a electric outlet sized blank panel. It almost looks like a screw or rivet.
Check the AS owner's manual for the radio/entertainment center section. Ask a dealer to show it to you. Ask another AS owner in the campground to show it to you.
Paul Bristol - In the wind!
2025 AirStream Trade Wind
2024 Ford Expedition Max LS with factory towing package
PaulBristol is offline   Reply With Quote
Old 05-15-2025, 09:09 AM   #8
Niagara Falls , Ontario
The light is probably only a small part of the draw.
If the light uses 1A I would change to an LED to save power.
hairyclive is offline   Reply With Quote
Old 05-15-2025, 09:23 AM   #9
2012 23' FB International
Woodstock , Ontario
It’s gotta be an LED in this day and age
JCWDCW is offline   Reply With Quote
Old 05-15-2025, 01:14 PM   #10
2024 19' Bambi
Essex , New York
Had the same issue on my 2024 Bambi. On my model, the rather tiny button is located on the side of the radio, not near the TV. From the replies it seems the location varies. Hope you figure it out.
Frost is offline   Reply With Quote
Old 05-15-2025, 07:05 PM   #11
2024 28' Flying Cloud
2004 25' Safari
Boston , Massachusetts
Some Fantastic Fans have a red light also
FLY28 is offline   Reply With Quote
Old 05-15-2025, 07:35 PM   #12
2023 25' Globetrotter
Ancient City , Florida
Aliens
G8trwood is offline   Reply With Quote
Old 05-21-2025, 09:18 AM   #13
gator.bigfoot's Avatar
KW , Ontario
That's a lot of power to loose if it's on all the time.
gator.bigfoot is offline   Reply With Quote
Old 05-21-2025, 10:06 AM   #14
2008 27' International FB
Oklahoma City , Oklahoma
Red light
Our fantastic fans have a small red light. I stays on if you close the lid but don’t turn the fan speed to off.
Americal is offline   Reply With Quote
Old 05-21-2025, 10:26 AM   #15
waninae39's Avatar
NCR , Ontario
the FF light is to detect rain and moisture
its actual an IR led, but cheap ones also show red
WBCCI# 21212
Old 05-21-2025, 11:38 AM   #16
2023 33' Classic
Chandler , Arizona
Perfectly normal. Same on my 2023 classic 33. The antenna booster button has no effect on the ‘RED LED’ being on. The milliamp draw is negligible and you shouldn’t be concerned.
Saullman is offline   Reply With Quote
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
Mysterious Orange Wires? DenverAaron Electrical - Systems, Generators, Batteries & Solar 8 10-07-2006 11:50 PM
Mysterious water behind shower ca_argonaut Plumbing - Systems & Fixtures 6 12-20-2005 12:09 PM
More Mysterious Disappearing Threads Hit'nMiss Forum Admin, News and Member Account Info 14 06-13-2005 10:43 PM
The mysterious world of electricity, or...... krowsea Electrical - Systems, Generators, Batteries & Solar 25 09-03-2004 03:23 PM
